Page 3 of 6 1 2 3 4 5 6
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1300828
09/14/12 10:10 PM
09/14/12 10:10 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
Waits patiently for more pics....
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: 340wedge] #1300829
09/16/12 04:56 PM
09/16/12 04:56 PM
Virginia's Eastern Shore
dmoore Offline OP
dmoore  Offline OP
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: 340wedge] #1300830
09/16/12 10:31 PM
09/16/12 10:31 PM
340wedge Offline
340wedge  Offline
Let me be the first to thank you Dmoore for posting the pics on these low mileage, survivor cars, personally i savor every detail. I have a question on the ceramic resistor on the wiper motor, was that painted over by the factory or is that undercoating? Thanks again..
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: 340wedge] #1300831
09/16/12 11:57 PM
09/16/12 11:57 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Keep the pictures coming!! Man that car is georgeous!! I could spend hours looking over that car at a show.
Can I make a picture request?
1) One that shows the top of the grille & the headlight bezel mounting fastener
2) Where the engine to firewall ground goes. Looks like the wiper motor to??
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: NV69B7RR] #1300832
09/17/12 01:28 AM
09/17/12 01:28 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Congratulations! Your Dusters are most definately the cream of the crop!
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: Airgrabber] #1300833
09/17/12 01:31 AM
09/17/12 01:31 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Great photos, great car.
Sheldon
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: Rhinodart] #1300834
09/17/12 02:03 AM
09/17/12 02:03 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I was trying to dig up pictures of the car, I believe it was a 70 and I talked with the original owner. I am sure Steve Wahl who runs the Spring Fling should have some pics and info.
Red on Red car was in MCG magazine. I think the article showed the owner had bought NOS door panels worrying that his would fade or wear out.
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: 340wedge] #1300835
09/17/12 09:55 AM
09/17/12 09:55 AM
dmoore Offline OP
dmoore  Offline OP
The complete wiper motor assy was painted on this particular car to include the resistor and the copper & brass I.D. tags unlike the yellow & white cars. I'm not sure why at this point...
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1300836
09/17/12 10:10 AM
09/17/12 10:10 AM
dmoore Offline OP
dmoore  Offline OP
Another interesting detail, of course not worthy of replication would be a slight mis-calculation of the relief holes made into the carpet at the drivers side location by the mfg...you can see the relief cut at the rear which is way outboard of the desired location and the same with forward but with the hole a little bit bigger...Interestingly enough there are body plugs at each location.......oooops!
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: autoxcuda] #1300837
09/17/12 10:12 AM
09/17/12 10:12 AM
dmoore Offline OP
dmoore  Offline OP
Thanks for posting autoxcuda, would you know which issue?
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1300838
09/17/12 10:17 AM
09/17/12 10:17 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks for the great pics Dave! Can you remove some speculation on my part and list as many the items that you can confirm as having been either replaced, restored, repainted, or retouched?
I see a few areas that raise questions and using your pics for future reference I'd like to weed out any misconceptions.
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1300839
09/17/12 01:49 PM
09/17/12 01:49 PM
dmoore Offline OP
dmoore  Offline OP
Scott, The radiator was recently restored by Bob over at Glen-Ray, The T'quad was rebuilt in the early nineties, I replaced the voltage reg with a date coded piece, Mopar restoration spark plug wires, fuel filter, battery was replaced roughly 3-4 years ago, the original water pump was rebuilt early nineties along with cork type valve cover gaskets and I believe the ignition module was replaced but cannot verify that.
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1300840
09/17/12 01:51 PM
09/17/12 01:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool, how about the ink stamps on the hoses?
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1300841
09/17/12 02:16 PM
09/17/12 02:16 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Looks like the nuts holding it on were as well tells me it was repainted along the lines somewhere by someone
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1300842
09/17/12 07:09 PM
09/17/12 07:09 PM
dmoore Offline OP
dmoore  Offline OP
Factory original hoses...and last I knew no one is reproducing that top hose....
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: gtx6970] #1300843
09/17/12 07:10 PM
09/17/12 07:10 PM
dmoore Offline OP
dmoore  Offline OP
I have talked to ALL owners of this car and know one has painted anything.....
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: 340wedge] #1300844
09/18/12 03:07 PM
09/18/12 03:07 PM
dmoore Offline OP
dmoore  Offline OP
Careful what you wish for
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: dmoore] #1300845
09/18/12 03:31 PM
09/18/12 03:31 PM
dmoore Offline OP
dmoore  Offline OP
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1300846
09/18/12 03:39 PM
09/18/12 03:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Do your leaf springs appear to be painted black? If so were the leaves painted individually or was the entire pack painted at once?
Re: 1972 FORMAL BLACK 340 DUSTER "SURVIVOR" [Re: ScottSmith_Harms] #1300847
09/18/12 04:02 PM
09/18/12 04:02 PM
dmoore Offline OP
dmoore  Offline OP
They are black Scott....And appear to have been painted as a unit..
