Re: replacing a single tire only
[Re: None2Slow]
#1300485
09/09/12 05:48 PM
09/09/12 05:48 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Something else to think about, tires do have a shelf life.
Had one go bad on the RR. Vibrated like nobody's business between 55-65 mph. Thought one of 'em was out of balance - nope. Had driveline balanced - nope. Replaced tires - yep.
Had one go bad recently on DD. Pulled to one side, figured out which one by swapping sides. Put it on the rear until time came to replace 'em all (they were near due - 12 years old.) Didn't make it. An internal defect caused enough of a slight bulge to wear more on inside tread without creating an out-of-balance condition. Came out one morning to a flat tire - worn right through to the steel cords. I got lucky - it could have been worse.
Got a used single on there now until snow tires go on for the winter, then new tires in the spring.
[Re: attaboy]
#1300494
09/10/12 02:09 PM
09/10/12 02:09 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I checked with the folks at Discount Tire today and they suspect that the problem is that I didn't replace both rear tires at the same time (that's what I thought they'd say) and that the other tire is 10 years old and still has 50% tread and is fighting the new tire for control....... They suggested buying another tire and "trying it out" to see if that helps. I think I'll do a bit more investigating before forking out yet another $130.
Does the car have a sure grip ? If it does swap the front tires , you say they are the same size as the rears , with the rear and see if it changes .
Otherwise , 10yr old tires , buy another , is the car worth less than 130 ?? Save the good rear as a spare .
