replacing a single tire only #1300482
09/09/12 04:28 PM
09/09/12 04:28 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
I just replaced the right rear BFG Radial TA tire on my 71 Charger R/T because I ran over something and ruined the tire. This tire was 10 years old and had about 50% tread left. I did not replace the other rear tire that also was 10 years old and had 50% tread left. The front two tires are also BFG TAs and are the same size as the rears (235 60 15). The car now handles really odd and feels loose and sloppy. Kind of like something is loose in the steering but I checked that and that seems to be OK. Should I have replaced both rear tires instead of just the one? Being that the old ones are so old, could the new one be even a different rubber compound and cause the behavior? Need some opinions regarding this.
Re: replacing a single tire only [Re: attaboy] #1300483
09/09/12 04:55 PM
09/09/12 04:55 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Well obviously buying two tires would be better. You might try putting the new tire on the front to see if drives better even though thats counter-intuitive.
Think also about when the other three tires wear out--then you will probably buy four right? If you buy another tire now when the other TWO wear out you have to buy two new ones......
Re: replacing a single tire only [Re: attaboy] #1300484
09/09/12 04:56 PM
09/09/12 04:56 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
New tires will ride "squishy" for a thousand miles or so. I just put 2 new rears on my F350 and same thing. Also, I drive big rig and for the first 3,000 miles or so it is really squishy. We put tires on near the end of summer so as to have them broke in by winter. Something else to think about, tires do have a shelf life. After about 6 years they are broken down and should be replaced anyways. The rubber breaks down. Really important on motorcycles.
Re: replacing a single tire only [Re: None2Slow] #1300485
09/09/12 05:48 PM
09/09/12 05:48 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Had one go bad on the RR. Vibrated like nobody's business between 55-65 mph. Thought one of 'em was out of balance - nope. Had driveline balanced - nope. Replaced tires - yep.
Had one go bad recently on DD. Pulled to one side, figured out which one by swapping sides. Put it on the rear until time came to replace 'em all (they were near due - 12 years old.) Didn't make it. An internal defect caused enough of a slight bulge to wear more on inside tread without creating an out-of-balance condition. Came out one morning to a flat tire - worn right through to the steel cords. I got lucky - it could have been worse.
Got a used single on there now until snow tires go on for the winter, then new tires in the spring.
Re: replacing a single tire only [Re: Pacnorthcuda] #1300486
09/09/12 06:04 PM
09/09/12 06:04 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
If I have to, I can get another new tire for the other side but I really don't want to spend another $130 if I don't need to. Tomorrow I'm going to give Discount Tire a call and see what they think too.
I really appreciate you guys' opinions. I may also try switching tire locations (back to front) as you suggested and see what that does. Just really odd how the handeling changed.....
Re: replacing a single tire only [Re: attaboy] #1300487
09/09/12 06:50 PM
09/09/12 06:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bet ya lunch a tire store says "replace in pairs"; not necessary unless MAYBE a traction-control system is so extremely sensitive that a TINY amount of OD messes with it.
Re: replacing a single tire only [Re: topside] #1300488
09/09/12 07:34 PM
09/09/12 07:34 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
I'm sure that they will recommend replacing them in pairs because they get to double the number of tires they sell but I'm counting on them giving me the "true skinny" regarding my handeling issue. However, they won't be the only ones I ask...
Re: replacing a single tire only [Re: attaboy] #1300489
09/09/12 08:48 PM
09/09/12 08:48 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Give it a bit of time. When we put new steering tires on big trucks we have to exercise caution for a few thousand miles as they are a bit greasy. Same as on a motorcycle, after you put new tires on a bike you better ride careful for a while.
People don't generally notice it on a car.
BTW, 10 years is a bit long in the tooth for tires to be mounted and in use on a car.
You did recheck torque on all the lugnuts though?
Sheldon
Re: replacing a single tire only [Re: RUNCHARGER] #1300490
09/10/12 03:15 AM
09/10/12 03:15 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Try replacing all 6 (single rear axle) on a big truck. Gets really greasy. Then pull triples. Ohhhh yeah, makes you need a pry bar to remove the seat. Just repalcing the 2 rears on my pick up and it made it a little twitchy. It made wider turns and just seamed to not be as responsive to turns. When changing lanes on the freeway, it seemed like it didnt want to go, then all of the sudden there I was and now I was trying to recover from an oversteer condition. Now the tires that I took off were really wore, past the wear bars. The new tires were 265/75/16s and were Michelin LTX M/S. Really nice thick tread. The new thick tread is what did it.
Re: replacing a single tire only [Re: attaboy] #1300491
09/10/12 08:10 AM
09/10/12 08:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Maybe you have a sure grip in your rear? If you do that will cause a funny feeling and wear out your sure grip quicker.
Re: replacing a single tire only [Re: attaboy] #1300492
09/10/12 10:40 AM
09/10/12 10:40 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I hope you only drive your R/T around town below 50 mph on those 10 year old tires. If you’re out there on the highway driving at 65 or 70 mph you’re an accident waiting to happen. Your R/T deserves better.
I just replaced the tires on my Super Bee because of age. They had less than 6,000 mile on them and looked like new. The car was in storage for eight years. I don’t trust any tire over six years old.
Re: replacing a single tire only [Re: Challenger 1] #1300493
09/10/12 12:31 PM
09/10/12 12:31 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
I checked with the folks at Discount Tire today and they suspect that the problem is that I didn't replace both rear tires at the same time (that's what I thought they'd say) and that the other tire is 10 years old and still has 50% tread and is fighting the new tire for control....... They suggested buying another tire and "trying it out" to see if that helps. I think I'll do a bit more investigating before forking out yet another $130.
Re: replacing a single tire only [Re: attaboy] #1300494
09/10/12 02:09 PM
09/10/12 02:09 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Does the car have a sure grip ? If it does swap the front tires , you say they are the same size as the rears , with the rear and see if it changes .
Otherwise , 10yr old tires , buy another , is the car worth less than 130 ?? Save the good rear as a spare .
