How much chain slop is too much? #1300255
09/09/12 09:19 AM
09/09/12 09:19 AM
Ohio
fiddlestix Offline OP
Ohio
I had my block line honed. I checked the crank to cam centerline @5.1485" (.0035 less than stock). I have a new Cloyes timing set I put on it and have aprox. .160" deflection in the chain. Is this too much? Should I go with a -.005 chain or will it be too tight? Any suggestions? Also what is your favorite brand you can buy with a torrington thrust bearing(Cloyes, rollmaster, comp)?
Thanks guys!!
Re: How much chain slop is too much? [Re: fiddlestix] #1300256
09/09/12 09:41 AM
09/09/12 09:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What block is it
Re: How much chain slop is too much? [Re: MR_P_BODY] #1300257
09/09/12 09:45 AM
09/09/12 09:45 AM
Ohio
Ohio
440
Re: How much chain slop is too much? [Re: fiddlestix] #1300258
09/09/12 10:02 AM
09/09/12 10:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know if they offer a chain tensioner for the
BB but they do for the SB... I believe that if you
go to the short chain it would be too short... JMO...
I was surprised at how much drag there was when using
the chain tensioner ... I was putting my engine together
a couple of days ago and with just the crank in the
engine I couldnt really measure the torque to turn
the crank(didnt want to get my inch pound torque wrench
out) and I put the cam in and could spin it with
my fingers... as soon as I pulled the pin on the
chain tensioner it went up to about 8# to turn the
crank..... I thought that was ALOT
Re: How much chain slop is too much? [Re: fiddlestix] #1300259
09/09/12 10:16 AM
09/09/12 10:16 AM
I ran into this recently on a 440, I bought a -.005 chain and that made it nice and tight mine had more than .160, I didn't measure it but it was probally closer to .250 total deflection In a stock block according to the owner I'm not sure if Cloyes still offers -.005,-.010 and -.-15 chains any more
Re: How much chain slop is too much? [Re: MR_P_BODY] #1300260
09/09/12 10:16 AM
09/09/12 10:16 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
No tensioner for big blocks that I'm aware of. Go to the Rollmaster website, they have a neat gauge that converts chain slop into an oversize measurement.
http://www.romac.com.au/Tunnel_Bores.html
You just may be able to use a .005 over set. Chains will stretch with use so to answer your question, its only too tight if you can't get it on.
Re: How much chain slop is too much? [Re: Stanton] #1300261
09/09/12 11:19 AM
09/09/12 11:19 AM
sweden
sshemi Offline
sshemi  Offline
sweden
How many degrees can you move the crank without the cam moving?
Re: How much chain slop is too much? [Re: Stanton] #1300262
09/09/12 11:23 AM
09/09/12 11:23 AM
Az
Crizila Offline
Crizila  Offline
Az
Good info! Thanks.
Fastest 300
Re: How much chain slop is too much? [Re: Crizila] #1300263
09/09/12 01:46 PM
09/09/12 01:46 PM
Ohio
Ohio
Thanks for the info. I assume I need to order a standard Rollmaster set to be able to use their measuring chart. Then I would have to order another set to match what I have. Sounds kinda expensive. I won't get a chance to mess with it until tomorrow. I will measure it using their technique tomorrow and post. Thanks guys!!
Re: How much chain slop is too much? [Re: fiddlestix] #1300264
09/09/12 03:36 PM
09/09/12 03:36 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
440 Source makes a .005 over chain. I bought their standard chain kit and an extra .005 over chain for my block that was fitted with aluminum caps and line bored. Standard chain still fit well. Couldn't get the .005 chain on. Nice looking kit, too.
[image][/image]
Re: How much chain slop is too much? [Re: fiddlestix] #1300265
09/09/12 04:19 PM
09/09/12 04:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You should be able to use any timing set (new) to determine the slop since stock is stock regardless of who makes it (waiting for the arguments here !!)
Oversize chains ?!?!?! All chains are the same - its the top sprocket that's oversize. Which allows you to replace worn chains with any "off the shelf" double roller chain.
A top quality and inexpensive oversize set is available from JP Performance out of Australia. Available through any Motorstate distributor. p/n jpp5606t-lb5
http://www.motorstate.com/site/?ct=131#goto74170
Re: How much chain slop is too much? [Re: Stanton] #1300266
09/09/12 06:23 PM
09/09/12 06:23 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I wonder if the statement about the oversize top sprocket is correct? seems that the lower sprocket is 1/2 the size of the top sprocket. If the top sprocket was larger then 2x diameter after a few revolutions the timing would be off. yes?
Re: How much chain slop is too much? [Re: rowin4] #1300267
09/09/12 07:02 PM
09/09/12 07:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
No, it has nothing to do with the sizes of the sprockets, it has to do with the number of teeth. As long as the top sprocket has twice as many teeth as the bottom sprocket and the chain pitch is close enough to fit, the cam will turn at half the speed of the the crank.
They can add to the diameter of the sprocket and the pitch of the teeth only changes ever so slightly. I imagine the top sprocket is also easier to hold to machine.
Re: How much chain slop is too much? [Re: Stanton] #1300268
09/09/12 07:07 PM
09/09/12 07:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
According to their web site its a matched set and
have to be used together....
Re: How much chain slop is too much? [Re: Stanton] #1300269
09/09/12 07:29 PM
09/09/12 07:29 PM
Not all chains or gears are the same for our motors I have experimented with different brands ans style, standard double roller versus True roller, definetly different The latest go around was with a older stock Mopar 3 bolt upper and lower gears with a stock replacemnt Cloyes chain for that appication, it was loose I bought and used a -.005 Cloyes chain, it tighten right up I couldn't switch any parts between the True Roller sets and the stock stuff
Re: How much chain slop is too much? [Re: Cab_Burge] #1300270
09/09/12 09:58 PM
09/09/12 09:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Any mention of "stock" was with regards to size only - not to the interchangeability of components.
And while I won't argue with you, I honestly find it hard to believe that someone would make an undersize chain. While it would be simple to machine an additional .010" in a sprocket's diameter, to make a (for example) .005 undersize chain would require each link to be "stanped" with an unbelievable tolerance. For example, there are approximately 72 links. Divide this into the .010 and you end up with each link having to be roughly 1/10,000 shorter than standard. Or alternatively you can make the rollers that much larger. I just can't see it!
Anyhow, give me an oversize sprocket any day!
Re: How much chain slop is too much? [Re: fiddlestix] #1300271
09/10/12 02:52 AM
09/10/12 02:52 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Ever considered a gear drive ?
Re: How much chain slop is too much? [Re: super451b] #1300272
09/10/12 10:12 AM
09/10/12 10:12 AM
Ohio
Ohio
I haven't considered the timing gears. I don't really like the sound. I rechecked the chain deflection. I believe I was forcing the chain a little hard on the first check. I get between .100" -.120". I am guessing this would probably be OK, but I'm checking into ordering a Rollmaster +.003 set. Am I wasting my time and money?
Re: How much chain slop is too much? [Re: fiddlestix] #1300273
09/10/12 12:56 PM
09/10/12 12:56 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I got tired of replacing timing chains every year so I decided to try a gear drive. That was ten years ago on my 383. I have them on both engines now and I'm happy I made the switch. I run the quiet type. They still have a slight whine to them but definitely not loud. The 383 has been align honed and the 451 has been align bored/honed with aluminum caps.
Re: How much chain slop is too much? [Re: fiddlestix] #1300274
09/10/12 03:04 PM
09/10/12 03:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Good luck there. Not many places stock a variety of the undersize sets and the delivery time is ridiculous if they order - made in Australia and shipped by boat!
Also, when I was looking for mine I was informed that they were only producing the .005 and .010 sets.
