Location for e-body Brake Line and Fuel Line Shields #1300233
09/09/12 08:41 AM
09/09/12 08:41 AM
Sweden
71redcuda Offline OP
Sweden
They are installed near the front of the leaf springs on each side of the car. I do not understand where these shields should be mounted? Can anyone show the correct location.. Bad picture but maby someone knows?
Nicklas
Re: Location for e-body Brake Line and Fuel Line Shields [Re: 71redcuda] #1300234
09/09/12 11:05 AM
09/09/12 11:05 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Re: Location for e-body Brake Line and Fuel Line Shields [Re: burdar] #1300235
09/09/12 01:02 PM
09/09/12 01:02 PM
Sweden
Sweden
Re: Location for e-body Brake Line and Fuel Line Shields [Re: 71redcuda] #1300236
09/09/12 10:40 PM
09/09/12 10:40 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Just an FYI - the 70 models use a strap with a slightly different design than the 71-74 models.
The later style will bolt up and fit but it is something to know if looking to find a set of originals.
Re: Location for e-body Brake Line and Fuel Line Shields [Re: C_B5] #1300237
09/14/12 09:43 PM
09/14/12 09:43 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Interesteing about the 2 different styles.Anybody got pictures of both they could post? Thanks
Re: Location for e-body Brake Line and Fuel Line Shields [Re: 44D6PAKCUDA] #1300238
09/15/12 12:52 AM
09/15/12 12:52 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Here is photo of the later style fuel / brake shield
Note the extra step in the metal strap opposite the bolt hole. When installed this design allows the shield to fit better over the lower pinchweld area.
I do not know exactly when the switch over occurred. However in my experience the shield without the step was used on 1970 cars and also some 1971 models. I have seen the later style (with step) starting on the 71 model and then definitely from 72-74.
Re: Location for e-body Brake Line and Fuel Line Shields [Re: C_B5] #1300239
09/15/12 05:35 AM
09/15/12 05:35 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I concur with that Chas.
Re: Location for e-body Brake Line and Fuel Line Shields [Re: HEMICUDA] #1300240
09/15/12 08:25 AM
09/15/12 08:25 AM
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Can someone dig up a photo of the '70 only bracket.Thanks Chas and Mikey for the info!!
Re: Location for e-body Brake Line and Fuel Line Shields [Re: 44D6PAKCUDA] #1300241
09/15/12 09:15 AM
09/15/12 09:15 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Original post by 71redcuda at the top of the page appears to be the exact shields used for 1970 (mine is a March 70 build).
Unless there is a slight dimensional difference in flange length, those would be 70 brackets
Re: Location for e-body Brake Line and Fuel Line Shields [Re: AAR#2] #1300242
09/15/12 05:29 PM
09/15/12 05:29 PM
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
I was hoping for a little better picture of '70 showing the side without the "step".Or were the repops patterned after the '70,no step brackets?
Re: Location for e-body Brake Line and Fuel Line Shields [Re: C_B5] #1300243
09/17/12 02:05 AM
09/17/12 02:05 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Here is a photo of the early shield used on 70 e-bodies.
Compare it to the other photo in my previous post and the difference can be clearly seen.
The examples of the parts that I have provided are both factory originals not reproductions.
This may or may not be the case with all vendors but the reproductions that I have seen are patterned from the later style shield with the step.
Re: Location for e-body Brake Line and Fuel Line Shields [Re: C_B5] #1300244
09/17/12 07:27 AM
09/17/12 07:27 AM
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Chas-Thanks for the addition photo and info on the brackets.Always a good day when you learn something new.It's tough to tell from the angle of your last picture,but is there a short,straight leg opposite the leg that has the bolt hole or is it just cut off flush?Thanks again for the help.
Re: Location for e-body Brake Line and Fuel Line Shields [Re: 44D6PAKCUDA] #1300245
10/28/12 08:42 AM
10/28/12 08:42 AM
Sweden
Sweden
What is the factory finish of these shields?
Re: Location for e-body Brake Line and Fuel Line Shields [Re: C_B5] #1300246
10/28/12 12:39 PM
10/28/12 12:39 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Style found on late 1973 and 74
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Location for e-body Brake Line and Fuel Line Shields [Re: 71redcuda] #1300247
10/29/12 02:23 PM
10/29/12 02:23 PM
Sweden
Sweden
Re: Location for e-body Brake Line and Fuel Line Shields [Re: 71redcuda] #1300248
10/29/12 09:07 PM
10/29/12 09:07 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Clear zinc, also Steve Bean with ECS has the most accurate repros if yours won't clean up.
MLR426
Re: Location for e-body Brake Line and Fuel Line Shields [Re: MLR426] #1300249
10/29/12 09:15 PM
10/29/12 09:15 PM
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
I have some originals that have the spangled galvanized finish.
