Re: Long wheel stud question?
[Re: bigblk66_coronet]
#1299915
09/08/12 10:11 PM
09/08/12 10:11 PM
Posts: 952 Queens, N. Y.
FASTBACK340
Queens, N. Y.
I just installed a set of Moroso 2 3/4" studs on my car. I pulled the axles and used the hydraulic press at work. The axles must come out, so you might as well re-pack the wheel bearings and swap out the axle seals. The means draining the rear so don't forget the sure grip additive and gear oil. I bought a nice hand pump at Auto Zone that screws onto the bottle and makes filling the rear a breeze. Also make sure you use anti-seize on the wheel studs & lug nuts. As for the actual selection of what to buy, most catalogs walk you through the choices.
`68 Barracuda 340-S
#1299916
09/08/12 10:17 PM
09/08/12 10:17 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Hey guys i want to switch over to long wheelstuds on the rear of my car. Im running an 8 3/4 in my 66 coronet. Not sure how to go about finding the right ones. Which ones do you suggest?....Joe
Contact Dr. Diff on here. He is a member on Moparts and is extremely well known. Dave
[Re: 67dodge67]
#1299917
09/09/12 07:28 AM
09/09/12 07:28 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
No need to drain the rear as the center section dosent come out.Installed the Moroso studs in my 65 and the kids 62 with newer rear end.You can actually install them by just knocking the axle studs out first.Then loosen the axle nuts and pull them out a bit.Install the new studs and use an old nut reversed with washers under it.Pull the studs thru the axle end and you are done.No press needed.On mine I needed to pull the axles all the way out so I used a deep well socket under the axle flange and the stud went in it and I just smacked them into the axle.Been 10 years and no problems.Did the same with the fronts.Rocky
Chrysler Firepower
[Re: therocks]
#1299918
09/09/12 08:03 AM
09/09/12 08:03 AM
FASTBACK340
Queens, N. Y.
Maybe I should have clarified my post: The CORRECT way to install axle studs, especially when the opening on my A body axles is .680 and the replacement studs are .720, is with a press. No need to stress-test the studs and pull them through over-tightening the stud with a socket jammed over it. It lasted 10 yrs? Good for you. And yes, if you pull both axles, it will leak out. Or you can wait until it's dripping and go look for a pan. Or just let it drip while you hammer in the studs....
`68 Barracuda 340-S
[Re: rbstroker]
#1299920
09/09/12 09:02 AM
09/09/12 09:02 AM
FASTBACK340
Queens, N. Y.
.040 difference is the closest you come with A body axles. Instead of trying to pull the studs through by over-tightening them I'm positive it's better to use a press. But I've only been wrenching for 35 yrs. and haven't seen much. But at the end of the day again, different people, different methods. What ever works for you. I was just trying to help (what sounded like...) a novice asking for advice. I try not to give short-cut, pound-it-in advice. Us pro's can do that...
`68 Barracuda 340-S
[Re: 70Cuda383]
#1299932
09/09/12 04:59 PM
09/09/12 04:59 PM
Challenger 1
Cincinnati, Ohio
Buy the best ones you can and not from the above venders, imo.
Any reason why you suggest to not buy from the above mentioned vendors like doc diff? Or did you mean something else?
I meant MP or Moroso because of my experience with MP and what Dr Diff has told us about Moroso.
