I've got gas. #1299785
09/08/12 05:19 PM
09/08/12 05:19 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
Yup, I have gas. I pull my '69 Super Bee into the garage, shut it off, and go inside. Within a few minutes, the house has a faint smell of raw gas, which is stronger in the garage (the garage is on the same level as the main floor, right next to the kitchen).
The car is all stock, well tuned, and has no leaks. Is this common? Or, is there something going on needing attention?
*1969 383 4sp. Super Bee
*1966 Alfa Romeo Giulia Sprint GT
*1965 Porsche 356C
*2004 VW Passat Wagon
*2004 Mini Cooper S
*1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: I've got gas. [Re: new bee] #1299786
09/08/12 05:57 PM
09/08/12 05:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'd go from one end to the other on the fuel system looking for stains caused by fuel leakage. I'd also pull the air cleaner and see if fuel was leaking into the carb after shut down.
Re: I've got gas. [Re: stumpy] #1299787
09/08/12 06:01 PM
09/08/12 06:01 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
yep,sniff you oil ,when it's unusal i would be out there looking while fresh
Re: I've got gas. [Re: meepmeep70] #1299788
09/08/12 06:14 PM
09/08/12 06:14 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
There are no gas leaks along the fuel system. I'll have to check the carb for leakage, though I would be surprised if that was the source. It has been recently restored by Scott (the same who does all the hemi carbs). Perhaps the fuel is boiling?
*1965 Porsche 356C
*2004 Mini Cooper S
Re: I've got gas. [Re: new bee] #1299789
09/08/12 08:24 PM
09/08/12 08:24 PM
Bingo, winner, winner, chicken dinner Let us know what you find
Re: I've got gas. [Re: Cab_Burge] #1299790
09/08/12 08:52 PM
09/08/12 08:52 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
thing is, I have the carb on spacers (about .25") to eliminate this problem.
*1965 Porsche 356C
*2004 Mini Cooper S
Re: I've got gas. [Re: new bee] #1299791
09/08/12 10:52 PM
09/08/12 10:52 PM
Central TX
roe Offline
roe  Offline
Central TX
What material? Wood and phenolic are supposed to be best. Aluminum is not as good
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: I've got gas. [Re: roe] #1299792
09/08/12 11:36 PM
09/08/12 11:36 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
metal
*1965 Porsche 356C
*2004 Mini Cooper S
Re: I've got gas. [Re: new bee] #1299793
09/09/12 12:03 AM
09/09/12 12:03 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Metal spacer will still transfers engine heat to the carb. Stay with the car for a few minutes after a hot shutdown, you may be able to hear the fuel boiling in the carb bowl.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: I've got gas. [Re: GO_Fish] #1299794
09/09/12 02:16 AM
09/09/12 02:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How is a metal spacer supposed to do anything? The carb is metal, the intake is metal. They still heat up the same. Get yourself a phenolic spacer.
Re: I've got gas. [Re: DaytonaTurbo] #1299795
09/09/12 10:57 AM
09/09/12 10:57 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Got a NG water heater in the garage?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: I've got gas. [Re: DaytonaTurbo] #1299796
09/09/12 01:18 PM
09/09/12 01:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Exactly!!! metal spacer??? Don't tell me it's one of those cool carb spacer.
If the fuel is not boiling then I would have to say your fuel tank is not vented properly.
Re: I've got gas. [Re: Challenger 1] #1299797
09/09/12 01:29 PM
09/09/12 01:29 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep, I'd be looking at the tank vents.
New Bee-----by chance is the fuel tank pretty full?
Many of these tanks have a habit of 'venting' raw fuel when really full!
Re: I've got gas. [Re: Pacnorthcuda] #1299798
09/09/12 02:21 PM
09/09/12 02:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The repro sending units have a return line port. There not a factory return line in early cars and most just get left with the plug on them.
I did that with the red cap plug that came with the sender. In about a year the cap started leaking. I don't think it's fuel rated and it was hard as a rock.
Does it smell more if the tank is full?
You could do a quick look in there with a flashlight.
Re: I've got gas. [Re: new bee] #1299799
09/09/12 03:38 PM
09/09/12 03:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your gonna get it from BOTH the carb and the tank
vent... the problem is the fuel... with alky in it
(all of it does) it boils at a lower temp and generates
more vapor... see if you can find a small charcoal
filter for the tank vent and isolate the carb with
a non metallic spacer
Re: I've got gas. [Re: MR_P_BODY] #1299800
09/09/12 03:47 PM
09/09/12 03:47 PM
Central TX
roe Offline
roe  Offline
Central TX
Where do you get the charcoal canisters? I'm in a similar boat, way to strong fuel fumes in my garage after parking. But I still need to go thru and verify my vent tubes are clear. No fluid leaks found for me either.
Re: I've got gas. [Re: roe] #1299801
09/10/12 01:27 PM
09/10/12 01:27 PM
South Carolina
W
warpspeed Offline
warpspeed  Offline
W
South Carolina
Good thread. I bet alot of people have this same problem. I know I do too. My 440 71 has this problem even though I have a insulating spacer on it to keep the temperature down on the carb. Still smell gas, but there are no leaks to be seen.
Re: I've got gas. [Re: warpspeed] #1299802
09/10/12 02:40 PM
09/10/12 02:40 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Take Bean-O now or people around you will leave.
MLR426
Re: I've got gas. [Re: warpspeed] #1299803
09/10/12 03:58 PM
09/10/12 03:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The spacer is only slowing the process , there is so much heat coming off the intake the ethanol in the fuel is still going to boil .
Re: I've got gas. [Re: JohnRR] #1299804
09/23/12 06:06 PM
09/23/12 06:06 PM
pasadena,md
red 69 runner Offline
pasadena,md
I got a cool carb spacer and it solved the probelem,also the car starts right up after sitting 15 or 20 minutes.before the cool carb i would have to crank and crank like it was flooded.
