Reverse indicator light location- 70 Bee #1297553
09/04/12 09:20 PM
09/04/12 09:20 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Switched my auto to a four speed and am wanting to know where the reverse indicator light is located on the dash. Could anyone post a pic? I've scoured the Internet but can't find one of a 70! Much appreciated!!!
Re: Reverse indicator light location- 70 Bee [Re: slowpoke] #1297554
09/04/12 09:24 PM
09/04/12 09:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70 Charger....
Re: Reverse indicator light location- 70 Bee [Re: DAYCLONA] #1297555
09/04/12 09:29 PM
09/04/12 09:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Reverse indicator light location- 70 Bee [Re: DAYCLONA] #1297556
09/04/12 09:35 PM
09/04/12 09:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Reverse indicator light location- 70 Bee [Re: DAYCLONA] #1297557
09/04/12 09:36 PM
09/04/12 09:36 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
I'm guessing they would be the same???? BTW is that just mounted in the plastic dash piece or is it through the metal part as well? I ask because the light I bought from Passon looks to use the mount as the ground.
Thanks again
Re: Reverse indicator light location- 70 Bee [Re: slowpoke] #1297558
09/04/12 09:48 PM
09/04/12 09:48 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks again
Larry, the 70 Charger pic above is my car, ..the 70 B body ralley dash frame is the same Dodge or Plymouth,...I just looked to confirm, the reverse light bezel is mounted to the plastic, and merely protrudes thru a rather larger hole in the metal frame behind it
Mike
Re: Reverse indicator light location- 70 Bee [Re: DAYCLONA] #1297559
09/04/12 10:52 PM
09/04/12 10:52 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
So I'd need to run a ground wire to the dash...
Thanks a bunch Mike! I really appreciate it.
