Re: Reverse indicator light location- 70 Bee
[Re: slowpoke]
#1297554
09/04/12 09:24 PM
09/04/12 09:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#1297555
09/04/12 09:29 PM
09/04/12 09:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#1297556
09/04/12 09:35 PM
09/04/12 09:35 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: slowpoke]
#1297558
09/04/12 09:48 PM
09/04/12 09:48 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I'm guessing they would be the same???? BTW is that just mounted in the plastic dash piece or is it through the metal part as well? I ask because the light I bought from Passon looks to use the mount as the ground. Thanks again
Larry, the 70 Charger pic above is my car, ..the 70 B body ralley dash frame is the same Dodge or Plymouth,...I just looked to confirm, the reverse light bezel is mounted to the plastic, and merely protrudes thru a rather larger hole in the metal frame behind it
Mike
