Page 1 of 4 1 2 3 4
Bulletproof 727? #129716
09/29/08 09:20 PM
09/29/08 09:20 PM
ohio
U
Unknown_element Offline OP
U
ohio
Im in the process of building a 727. How can i build it to handle a 600hp street motor, and strip on the weekends?
Re: Bulletproof 727? [Re: Unknown_element] #129717
09/29/08 09:57 PM
09/29/08 09:57 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
In my mind you don't have to do much. Make sure you have the 4 set plantaries and the better sprag and a shift kit and you should be fine. pretty much a trans from a motor home has all of that.
Re: Bulletproof 727? [Re: Diablo] #129718
09/30/08 05:38 AM
09/30/08 05:38 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
super sprag & billet steel drum for a street car, for safety!
Talk to CRT here for more info!
Re: Bulletproof 727? [Re: DJVCuda] #129719
09/30/08 07:34 AM
09/30/08 07:34 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: Bulletproof 727? [Re: Unknown_element] #129720
09/30/08 10:11 AM
09/30/08 10:11 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There is no such thing as a bulletproof 727 , put enough power to even the best built unit with all the expensive parts and you can still turn it into a pile of scrap .
I just built one for a 650ish HP engine , but it's not the HP its the TORQUE that will hurt it , it wasn't cheap and I didn't go all out .
A+A ultimate sprag $175
A+A Front Billet Steel drum $695
4 pinion planet with a steel spline front and rollerized $425
Red lined soild front Band $?
Kevlar lined rear band $?
Red Alto Clutches and Kolene Steels $?
Teflon seals on front drum and input shaft $?
Billet front and rear servos $180
Billet spring retainer for the front drum $45
CRT Low band apply reverse manual VB $275
4.2 Lever $35
HD front band strut $25
Modified stator support $90
Billet pump gears $175
I'm sure I missed something , I have to go thru the pile of receipts still
Re: Bulletproof 727? [Re: JohnRR] #129721
09/30/08 10:13 AM
09/30/08 10:13 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
A bulletproof and cheap 727 is called a TH400
Re: Bulletproof 727? [Re: domingo] #129722
09/30/08 10:17 AM
09/30/08 10:17 AM
JohnRR Offline
JohnRR  Offline
I doubt that you can't just pull one out of a pickup and throw it your race or hot street motor ...
People go to the TH400 because of the design , NOT the cost .
Re: Bulletproof 727? [Re: JohnRR] #129723
09/30/08 10:21 AM
09/30/08 10:21 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Well, I dont know....but if you are talking about a real buletproof 727, I think the TH400 ends upo being cheaper and a lot stronger in the end....thats when you go for the all bells and whistles 727 of coourse with the rollerized shebang and all.
Re: Bulletproof 727? [Re: QWK_ENUF] #129724
09/30/08 10:51 AM
09/30/08 10:51 AM
organ
maximum entropy Offline
organ
Re: Bulletproof 727? [Re: maximum entropy] #129725
09/30/08 05:41 PM
09/30/08 05:41 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I just a video on bill meyers dodge with an A&A 727 and at 3500 pounds running 8.20.I dont know if he has broken anything but sounds like the 727 holds up to alot if built right
Re: Bulletproof 727? [Re: Otherlane] #129726
09/30/08 06:45 PM
09/30/08 06:45 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
All my buddys are gm guys. None of them make the power that I have, and they all weigh less than me. I can tell you this... None of them have anywhere near the trouble free operation that my A&A built 727 had. My car=3700lb, 3.50 rear gear,8.85/155 best. Trans was freshened once in 5 years after a rear end failure. Cost is a factor, but at a certain level, both trans' will cost$$$
Re: Bulletproof 727? [Re: TRENDZ] #129727
09/30/08 11:55 PM
09/30/08 11:55 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I got a bunch of stuff from A and A and couldn't be happier with the service or the product.
How much cheaper can a TH400 possibly be? You still have to beef it up, and then adapt it to the dodge motor.
I spent around 1K for what I needed. Heavy duty clutches, billet drum, 16pin sprague, low band apply VB, ridged KD band etc.. etc..
Re: Bulletproof 727? [Re: dave571] #129728
10/01/08 12:14 AM
10/01/08 12:14 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
It doesn't matter what make of trans it is really, most using high end parts end up costing the same. I have dealt with both John Cope and Rick Allison and was happy with both. Would deal with them again in the future for my next transmission build.
AL....
Alan Jones
Post deleted by moparts [Re: LA360] #129729
10/01/08 12:37 AM
10/01/08 12:37 AM
Re: Bulletproof 727? #129730
10/01/08 01:32 AM
10/01/08 01:32 AM
dave571 Offline
dave571  Offline
No one likes to burn money, but I guess the question becomes, how much are your feet worth?
I've seen a 500 hp small block scatter a 727 like it was made of fine china.
That was with a manual valve body, a basic rebuild kit, and an extremely knowledgable local builder.
Sprague failure blew it right out the bottom. You could see into the case, and actually look at the steels and clutches that were left of the front drum(drum long gone.) Only blind luck it blew out the bottom, instead of up through the floor.
I dimantled my own following the incident, to find I only had 2 of 12 oneway springs remaining in my own 727. I could have blown the same way at any time.
All with less than 600 hp.
Post deleted by Defbob [Re: JohnRR] #129731
10/01/08 03:48 AM
10/01/08 03:48 AM
Post deleted by Defbob #129732
10/01/08 03:56 AM
10/01/08 03:56 AM
Re: Bulletproof 727? [Re: dave571] #129733
10/01/08 04:58 AM
10/01/08 04:58 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
That is what alot of people dont realize!
Re: Bulletproof 727? #129734
10/01/08 06:03 AM
10/01/08 06:03 AM
Arizona
Chris'sBarracuda Offline
Arizona
they are as strong if not stronger than a P/G out of the box. I have a stock P/G in my Duster using Alto clutches and a good band with a t brake. Over a few hundred passes and zero problems with 6000 + RPM launches.Took it down about 75 runs ago and only replaced a few clutches that show very minor wear and only did that because I had them sitting in the shop. Otherwise I would have buttoned it right back up. I am sure a 400 is just as durable. Cost is much cheaper than building a comparable 727.
You're beating that "Dead Horse" again Fred.. Happy B-Day..
I vote P/G too, but some don't get it or just don't want to hear it..
If you have to put a Torqueflite in it..Call these guys..
Pro Trans.. Dave Smith
Street: 42156 10th St W
Lancaster, ca 93534-
Phone: (661) 940-7400
Chris..
Re: Bulletproof 727? #129735
10/01/08 10:11 AM
10/01/08 10:11 AM
JohnRR Offline
JohnRR  Offline
saw John's post on cost over 2100.00 then came across this which is about the same P/G unit I use from Trans Specialties.cheap and strong. they build one for 1800 Hp with after market parts for 2800.00
TH-400 Chevy Racing w/Reverse Manual Valve Body [40011] $1,267.00
Rated to 850 HP Deep steel pan Reverse manual valve body
Well I stand corrected, but don't forget to add $300 - $500 for either the adaptor OR an ultrabell .
Page 1 of 4 1 2 3 4
