440 Question #129662
09/29/08 07:12 PM
09/29/08 07:12 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
On a 440 with a cast crank will i need weights on the converter?
Re: 440 Question [Re: bobs69] #129663
09/29/08 07:14 PM
09/29/08 07:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes.
Re: 440 Question [Re: DaytonaTurbo] #129664
09/29/08 07:18 PM
09/29/08 07:18 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
If i change to a steel crank motor will i need to take the weights off the converter.
Re: 440 Question [Re: bobs69] #129665
09/29/08 07:21 PM
09/29/08 07:21 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Or use a weighted flex plate
Re: 440 Question [Re: bobs69] #129666
09/29/08 07:21 PM
09/29/08 07:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
No weights if you use the LY rods, not big beam six pac type.
Re: 440 Question [Re: bobs69] #129667
09/29/08 07:33 PM
09/29/08 07:33 PM
Manitoba, Canada
Manitoba, Canada
Yep. Generally...
cast crank = weighted covnerter
forged crank w/ ly rods = non-weighted/neutral balance converter
forged crank w/ 6pack rods = weighted converter
Also in the late 70's there was the odd combo of the cast crank, weighed converter and 6 pack rods. I can only imagine how poorly that would have balanced, but they did it and got away with it.
And keep in mind, if you need a weighted converter, you also need an external balance type balancer. If need a zero balance converter, then you need a zero balance balancer to go along with it. The two have to match and be the same type for the crankshaft you are using.
Re: 440 Question [Re: DaytonaTurbo] #129668
09/29/08 07:40 PM
09/29/08 07:40 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Feel free to call me odd then
You just described my combo to a tee save I have a weighted flexplate and neutral conv.
I'm ok being odd
Re: 440 Question [Re: buildanother] #129669
09/29/08 07:56 PM
09/29/08 07:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Most all cast crank motors used LY rods and had weighted balancer and convertors .
i have a 440 with big rods , forged TRW pistons and it needed very little weight added to NEUTRAL balance it .
YMMV
Re: 440 Question [Re: JohnRR] #129670
09/29/08 08:29 PM
09/29/08 08:29 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
We got a race car with a cast crank 440 took it out without thinking of looking at the converter. Replaced it with an eagle crank with manley rods 440. If the converter had weights on it am i going to have a vibration?
Re: 440 Question [Re: bobs69] #129671
09/29/08 08:30 PM
09/29/08 08:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
YES
