Re: 440 Question
[Re: bobs69]
#129665
09/29/08 07:21 PM
09/29/08 07:21 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Or use a weighted flex plate
Re: 440 Question
[Re: bobs69]
#129667
09/29/08 07:33 PM
09/29/08 07:33 PM
DaytonaTurbo
Manitoba, Canada
If i change to a steel crank motor will i need to take the weights off the converter.
Yep. Generally...
cast crank = weighted covnerter forged crank w/ ly rods = non-weighted/neutral balance converter forged crank w/ 6pack rods = weighted converter
Also in the late 70's there was the odd combo of the cast crank, weighed converter and 6 pack rods. I can only imagine how poorly that would have balanced, but they did it and got away with it.
And keep in mind, if you need a weighted converter, you also need an external balance type balancer. If need a zero balance converter, then you need a zero balance balancer to go along with it. The two have to match and be the same type for the crankshaft you are using.
Re: 440 Question
[Re: DaytonaTurbo]
#129668
09/29/08 07:40 PM
09/29/08 07:40 PM
WILD BILL
BROOK PARK, OH
Feel free to call me odd then
You just described my combo to a tee save I have a weighted flexplate and neutral conv.
I'm ok being odd
Re: 440 Question
[Re: buildanother]
#129669
09/29/08 07:56 PM
09/29/08 07:56 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
No weights if you use the LY rods, not big beam six pac type.
Most all cast crank motors used LY rods and had weighted balancer and convertors .
i have a 440 with big rods , forged TRW pistons and it needed very little weight added to NEUTRAL balance it .
YMMV
Re: 440 Question
[Re: bobs69]
#129671
09/29/08 08:30 PM
09/29/08 08:30 PM
JohnRR
U.S.S.A.
We got a race car with a cast crank 440 took it out without thinking of looking at the converter. Replaced it with an eagle crank with manley rods 440. If the converter had weights on it am i going to have a vibration?
YES
