Pop up Hood Spring / Paint Protection #1296572
09/03/12 11:29 PM
09/03/12 11:29 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Curious what some of you are using over top of your pop up hood spring to protect your paint. I really dont wanna scratch the freshly painted hood.
Re: Pop up Hood Spring / Paint Protection [Re: faud88] #1296573
09/04/12 08:17 AM
09/04/12 08:17 AM
crlush Offline
crlush  Offline
I fit some shrink tubing around a few coils , some springs you can fit a body plug on top of it.
Re: Pop up Hood Spring / Paint Protection [Re: crlush] #1296574
09/04/12 09:32 AM
09/04/12 09:32 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Small section of rubber windshield washer hose over end of spring .
Re: Pop up Hood Spring / Paint Protection [Re: faud88] #1296575
09/04/12 02:08 PM
09/04/12 02:08 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
Rubber pad from a Ford Windstar hood spring. Fits our Mopar springs perfectly. I bought mine new at the Ford dealer, spring and cap, for 12.00. I'm told that Ford has no more, as apparently us Mopar guys bought them all...
The Ford spring is the same physical size, but the OD of the actual coil wire is smaller, so it has less pop-up pressure. I tried using the Ford spring as-is, but sometimes it would pop-up, sometimes not, so I placed the rubber pad on my original Mopar spring.
It's a great solution, and I've had many of my Mopar buddies comment on how nice it looks and works... Bet you could find one at Pick-N-Pull.
Re: Pop up Hood Spring / Paint Protection [Re: faud88] #1296576
09/04/12 02:19 PM
09/04/12 02:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've seen 35 mm film container caps on springs...
Re: Pop up Hood Spring / Paint Protection [Re: 318 Stroker] #1296577
09/04/12 04:40 PM
09/04/12 04:40 PM
SE Pa.
LimeliteAero Offline
SE Pa.
you have a picture of this?
Re: Pop up Hood Spring / Paint Protection [Re: LimeliteAero] #1296578
09/04/12 05:48 PM
09/04/12 05:48 PM
St. Louis, Mo
3
St. Louis, Mo
I can take a picture for you. Haven't figured out how to post it to Moparts yet, but I can e-mail it to you. If you can post it here for the other members, that would be great.
I'll take the pic this evening and e-mail to you.
Re: Pop up Hood Spring / Paint Protection [Re: 318 Stroker] #1296579
09/04/12 06:22 PM
09/04/12 06:22 PM
SE Pa.
SE Pa.
Re: Pop up Hood Spring / Paint Protection [Re: Challenger 1] #1296580
09/04/12 07:43 PM
09/04/12 07:43 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Kodak film to be exact.
Re: Pop up Hood Spring / Paint Protection [Re: Pntastar69] #1296581
09/04/12 10:26 PM
09/04/12 10:26 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Thanks for all of the ideas. I would love to see the ford setup as well if anyone has a pic.
Re: Pop up Hood Spring / Paint Protection [Re: faud88] #1296582
09/05/12 12:40 AM
09/05/12 12:40 AM
St. Louis, Mo
3
St. Louis, Mo
I e-mailed the pics to LimeLiteAero. Not sure if they went thru. Just got a new computer, but sent them from the old one, as I know how to use it better. I know that sounds goofy...don't ask...
If he got them, he'll post them. If not, I'll figure out how to send them to you...
Re: Pop up Hood Spring / Paint Protection [Re: 318 Stroker] #1296583
09/05/12 08:20 AM
09/05/12 08:20 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I've used the Ford Aerostar rubber piece for years.
NMCA NSS 67 Coronet
Re: Pop up Hood Spring / Paint Protection [Re: Barry70GTX] #1296584
09/05/12 08:58 AM
09/05/12 08:58 AM
SE Pa.
SE Pa.
thanks to 318 Stroker here are more pics of the Ford part.
Re: Pop up Hood Spring / Paint Protection [Re: LimeliteAero] #1296585
09/05/12 01:49 PM
09/05/12 01:49 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I wonder how the "plastic-dip" stuff would hold up on the the first couple coils? That would be less conspicuous than a full rubber bumper.
Re: Pop up Hood Spring / Paint Protection [Re: RTshaker] #1296586
09/05/12 11:27 PM
09/05/12 11:27 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Same here...Cut to length and slip it over the center section...Not too noticeable and does the job perfectly..
Re: Pop up Hood Spring / Paint Protection [Re: 6pkaar] #1296587
09/06/12 05:47 AM
09/06/12 05:47 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
That's what I use and it works perfect. You have to make absolutely sure you only dip the very last coil of the spring at the very top or the hood will not close. I got that figured out the first time I did it.
Re: Pop up Hood Spring / Paint Protection [Re: 318 Stroker] #1296588
09/06/12 08:35 PM
09/06/12 08:35 PM
robertop Offline
robertop  Offline
Right, I just went to a local Ford dealer and was told they are no more available, so the best bet is to find one in a junkyard, I guess.
Re: Pop up Hood Spring / Paint Protection [Re: robertop] #1296589
09/06/12 10:11 PM
09/06/12 10:11 PM
SE Pa.
SE Pa.
could someone confirm if it was a WINDSTAR or a AEROSTAR?
Re: Pop up Hood Spring / Paint Protection [Re: faud88] #1296590
09/06/12 10:25 PM
09/06/12 10:25 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
My fix for the mentioned issue is for the other end, on the hood.
I took a body washer about 1.25" in diameter and mounted it with a single self tapping screw. So now the spring has a solid contact surface to push on..
Just my $0.02...
Re: Pop up Hood Spring / Paint Protection [Re: 6pkaar] #1296591
09/06/12 11:25 PM
09/06/12 11:25 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Works great...
