9/17/68 383 block in 70 Roadrunner...#s matching? #1296353
09/03/12 05:59 PM
09/03/12 05:59 PM
Vancouver,Canada
70 Roadrunner* Offline OP
Vancouver,Canada
I just discovered my VIN# stamped on the passenger side of my block just above the oil pan.It's a 70 Roadrunner (built August 1969)but my block is #2468130-12 (LL) dated 9/17/68...is there any possibility that this is the original engine or some previous owner stamping the VIN on the passenger side of the block.The stamping looks perfectly applied.I've had the car for 1 1/2 years and just noticed this today.I know production activities were "use what's around" sort of but could this possibly be it's original engine.Fender tags is as follows...
N85 N96 R11 V21 V8X 26
V1X A36 G33 J25 J45 M21
EV2 H2X9 TX9 903 046084
E63 D21 RM23 NOG ......
On the top right corner there's a "B" punched out of the tag.I'm relatively new to all this guys so if I mentioned something incorrect bare with me.If anyone has any info/advice/wisdom,whatever...please drop me a line...thanks
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296354
09/03/12 06:07 PM
09/03/12 06:07 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Post pictures of the stampings and the tag, please.
What is stamped on the ID pad on the passenger side deck surface, this is the assembly date and model year info, the casting date is not the definitive date to use, inventory control was not that great and there could have been an issue that had that block put aside for whatever reason.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: JohnRR] #1296355
09/03/12 06:23 PM
09/03/12 06:23 PM
Vancouver,Canada
Vancouver,Canada
ok...pic upcoming...is it ok to put my VIN up on the site?
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296356
09/03/12 06:37 PM
09/03/12 06:37 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
If you don't, I can. j/k
If you own it - there is no issue with posting the VIN; if you are chasing the car, and don't want to lose the chance to own it, don't post it.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 6bblgt] #1296357
09/03/12 07:00 PM
09/03/12 07:00 PM
Vancouver,Canada
Vancouver,Canada
...good one,and yup,I own the car..
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 6bblgt] #1296358
09/03/12 07:23 PM
09/03/12 07:23 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
With your car being a very early built car for 1970, I can see a 69 engine in it but not a 68 engine..
I am truckless..
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296359
09/03/12 07:25 PM
09/03/12 07:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Engine is a re-stamp.
The punch out is an inspectors mark.
The car was built early, the Mylar month is before the scheduled production date on the fender tag.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296360
09/03/12 07:26 PM
09/03/12 07:26 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Fender tag is authentic
Door sticker appears authentic
Engine VIN# has been "re-stamped" - NOT ORIGINAL
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 340SHORTY] #1296361
09/03/12 07:28 PM
09/03/12 07:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 1970 model year ran from August 1, 1969 until July 31, 1969. So this car would have had a 1969 or earlier cast block. A year or more early is fairly common.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: Alaskan_TA] #1296362
09/03/12 07:31 PM
09/03/12 07:31 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The car was built late, the Mylar month is after the scheduled production date on the fender tag.
The other way around - car scheduled for September '69 but built in August '69.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 6bblgt] #1296363
09/03/12 07:32 PM
09/03/12 07:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I edited it already.
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: Alaskan_TA] #1296364
09/03/12 10:05 PM
09/03/12 10:05 PM
Vancouver,Canada
Vancouver,Canada
So no way it's the original engine? I'm just trying to figure this all out...and yes,I'm new-ish to the car as well as the hobby.But man I love this car...
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296365
09/03/12 10:13 PM
09/03/12 10:13 PM
Vancouver,Canada
Vancouver,Canada
"Re-stamped"...what does that mean? Someone simply faked a stamp of the VIN on the engine block? If that's the case someone's going to hell...I was having such a great day...
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296366
09/03/12 10:21 PM
09/03/12 10:21 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
The person you bought the car from............did they advertise it as a numbers matching car???
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296367
09/03/12 10:31 PM
09/03/12 10:31 PM
U.S.S.A.
U.S.S.A.
The factory did not stamp the full VIN on that pad in 1970 nor does the factory stamp font look like that. Someone did that to that block and they were not at the plant that assembled that car when it was done.
Whats on the ID pad up top , passenger side of the engine behind the alternator, in front of the head?
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: JohnRR] #1296368
09/04/12 12:05 AM
09/04/12 12:05 AM
Vancouver,Canada
Vancouver,Canada
These are the marks on the top of the engine on the passenger side behind the distributor.No idea what they mean aside from the obvious 383...my buddy told me it was a replacement block as the original was blown up but upon further review I ended up knowing more about the numbers on the car than he did...
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296369
09/04/12 12:14 AM
09/04/12 12:14 AM
U.S.S.A.
U.S.S.A.
E 383 , it's a 1969 model year engine , a REPLACEMENT engine would more than likely not be stamped with the model year , and not the year prior to the one it was installed in . It was assembled on 10/16/1968 which is right inline with it's casting date , the R tells you it was built to run on regular fuel , which means it was a 290HP 2bbl equipped 383 as originally built.
Your buddy needs to do some more studying ...
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: JohnRR] #1296370
09/04/12 01:01 AM
09/04/12 01:01 AM
Vancouver,Canada
Vancouver,Canada
I just crawled out from under the car and took all the numbers off the 18-spline 4spd...
Passenger side shows the following...
23113812
E3 97622
PP8332239 01 70
Drivers side shows this on a tag attached ...
C 95664 and a possible casting showing 71-8
My VIN# is RM23NOG113812...it's looking to me like someone a long time ago (not my buddy but before him) was trying to pass this car off as numbers matching?
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296371
09/04/12 01:05 AM
09/04/12 01:05 AM
U.S.S.A.
U.S.S.A.
A 383 Road runner would not have an 18 spline 4 speed , only the 23 spline with a 383 .
Go a picture of that pad also ?
Re: 9/17/68 383 block in 70 Roadrunner...#s matching? [Re: 70 Roadrunner*] #1296372
09/04/12 01:21 AM
09/04/12 01:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
+ END
N85 N96 R11 V21 V8X -26
E63 D21 RM23 N0G 113812
Great Car!!
END = end of codes
N85 = tachometer
N96 = "AIR GRABBER" hood
R11 = AM radio
V21 = performance hood paint
V8X = deck lid stripe - black
26 = 26" radiator
V1X = vinyl top - black
A36 = "performance axle package" - 3.55s & 8-3/4"
G33 = LH remote chrome mirror
J25 = 3-spd windshield wipers
J45 = hood pins
M21 = drip trough mouldings
EV2 = body paint - "tor-red metallic"
H2X9 = high-grade vinyl bench seat interior - black
TX9 = upper door frame paint - "black velvet"
903 = scheduled production date - Wednesday, 9/3/69
046084 = vehicle order number
E63 = 383 cu.in. 4bbl engine
D21 = 4-spd manual transmission
RM23 = Road Runner 2 dr hardtop
N0G = 383 4bbl / 1970 / St. Louis MO assembly plant
113812 = VIN sequence number
A pic of my old EV2 '70 Road Runner
