Page 2 of 3 1 2 3
Re: need some carb tune advice [Re: We The People] #1295840
09/05/12 01:33 PM
09/05/12 01:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thanks, thats a great idea. honestly I hadn't thought of that, since I'm in the boondocks. I'll have to search chassis dynos near me, I'll probly have to tow three hours.........or cross over to canada and deal with the border gestapo.
It is a good idea but why not hook up a wide band and have a year round dyno at your finger tips plus, your not moving on the chassis dyno which changes your wot readings...........
Re: need some carb tune advice [Re: Thumperdart] #1295841
09/05/12 07:30 PM
09/05/12 07:30 PM
Communist New York State, Comi...
W
We The People Offline OP
W
Thats a good idea too. Right now I'm broke though....so I'm still gonna mess with it myself for a bit.
Heres where I'm at now (for those who care, or maybe just following along giggling) I'm gonna put the 3.5 and 3.0 pvs in to eliminate fuel dribble with wandering vac. I locked the dist. @ 26* initial, so I can experiment slowly at idle increasing the timing. I thought 26* initial would be enough but now I'm thinking low initial may have been affecting things more than I expected. I may also have a custom advance bushing made if I end up with some #s like 30* initial 10* start retard and 2*-5* mech. advance.
I measured the IFRs wich are .035 P and .037 S ( anyone know if .035 is enough for 2 circut idle on a 266 @.050 493?)
I wish MSDs start retard was more finite in it adjustability, the 5* jumps make it hard.
Re: need some carb tune advice [Re: We The People] #1295842
09/05/12 08:53 PM
09/05/12 08:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have the timing set right FIRST.... next WHY are
you at 2.25 or more turns out on the mixture screws...
you should be about 1 1/4 turns out
Re: need some carb tune advice [Re: MR_P_BODY] #1295843
09/05/12 09:30 PM
09/05/12 09:30 PM
W
W
yes, the screws are out there cause thats where it would run...I thought the timing was good cause it would run pretty well and start, (getting close) but with out kicking back.
Now... I am thinking it may need more timing to run well..and I'll need to utilize more * in the start retard.
I'll be going back to a bit of a baseline of 26* with 5* start retard, while locked out. Then I'll get it idling and bring the timing up a bit at a time.
I know it will ping in gear @ 35* cause the big 10* advance bushing stuck out once (needed some more oblonging).
I'm thinking I've got about 6* to mess with and look for the sweet spot. Then a more custom bushing may come into play.
I'm learning a lot as I go here, and trying not to break stuff. Kinda fun .........kinda a pain
Re: need some carb tune advice [Re: We The People] #1295844
09/05/12 09:42 PM
09/05/12 09:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Turn the start retard off and lock the dist... set
the timing at 18*-20* dont worry about total YET...
you need to figure out the basic timing and get the
carb set.... once you know some basic numbers you
can figure the total needed and then use your retard
Re: need some carb tune advice [Re: MR_P_BODY] #1295845
09/05/12 11:08 PM
09/05/12 11:08 PM
W
W
Yeah, thats about where it starts to liven up 21* (no retard) it fires and runs, you can just feel the starter begining to work there. Is it normal for the motor to want more near the kick back point, or is it just an every ones unique type thing?
I know I'm getting closer bit by bit, feels like a science experiment
Re: need some carb tune advice [Re: We The People] #1295846
09/05/12 11:13 PM
09/05/12 11:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you SURE the cam is in right... did you degree it
EDIT
Is this MSD ignition... sounds like the dist wires are
backwards
Re: need some carb tune advice [Re: MR_P_BODY] #1295847
09/05/12 11:38 PM
09/05/12 11:38 PM
W
W
yes it was degreed to spec, it is MSD. I've used the dist before in my 440 ran 11.01 @ 121 all wiring is the same, and I took this 493 for a ride. Theres nothing that drastic wrong, just my limited fine tuning experience, and maybe an ill matched carb. Plus its not licensed yet so I cant drive it around freely for testing.
thanks
Re: need some carb tune advice [Re: Thumperdart] #1295848
09/05/12 11:45 PM
09/05/12 11:45 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I will never build another car boosted or not without a wideband. I have saved alot of time pulling my hair out by getting an Innovate that datalogs
Re: need some carb tune advice [Re: SLOW67] #1295849
09/06/12 12:07 AM
09/06/12 12:07 AM
W
W
yeah Guys, NO doubt there great. I do plan on getting a wide band for next year, when I can drive it on the road.
but Right now you don,t even need it to know it is rich as hell idling. I'd be happy with a ball park decent idle, so I can store the car happy.
The problem more lies in the fact that if I had a wide band and it told me I was way rich at Idle, I'd still have to figure out how to cut it back, smooth it out, and keep the car running. Thats what is giving me the fits, the normal procedures dont seem to be netting goals. Maybe I'm asking too much of the old 850dp.
Does any one no if a 2 circut idle with .035 IFRs will run a 493 with this 266 @.050 cam?
I was looking at the 850 mighty demon........looks good
"I'm making a drink and getting in my hottub"
Me
thanks everyone
Re: need some carb tune advice [Re: We The People] #1295850
09/06/12 12:28 AM
09/06/12 12:28 AM
mi
rbj Offline
rbj  Offline
mi
Try another carb that you know works well, (friends, or off another ride),to see if it reacts the same. If it corrects then it s carb if not you have other issues but will tell you if it is carb tuning. Air screws should only be out , what p body said. Turn them for most vacuum in gear at idle. Power valve should be half of max vacuum. Just my
Re: need some carb tune advice [Re: MR_P_BODY] #1295851
09/06/12 01:03 AM
09/06/12 01:03 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This is where the t-slot mod comes into play .........why not try a smaller(richer)idle bleed to get the screws closer to 1-1 1/2 turns out........
Re: need some carb tune advice [Re: We The People] #1295852
09/06/12 01:16 AM
09/06/12 01:16 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
It sounds to me like you need to open the idle feed jets a couple of sizes. I know you said it's rich but it behaves like it's lean at idle. If it's lean enough to cause a misfire you WILL get fuel out of the exhaust because of the misfire. This can even throw off those tuning with a wideband.
Re: need some carb tune advice [Re: @#$%&*!] #1295853
09/06/12 01:26 AM
09/06/12 01:26 AM
W
W
yes, I believe it may be lean as far as the idle circuts go. which forces me to open the blades into the t slot to get fuel to it. BUT the t slot then makes it Too rich, then the vac drops and makes the pv open and worsens the problem.
the reason I think this way is, cause no matter how big I drill the plate holes I still have to open the blades into the t slots the same amount. I think it may need the t slot fuel cause the IFRs are too small.
Does this make sense to anyone else?
Re: need some carb tune advice [Re: We The People] #1295854
09/06/12 01:35 AM
09/06/12 01:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you drilled the plates I think you screwed them
up... did you pull the mixture screws out and blow
air through the holes
Re: need some carb tune advice [Re: MR_P_BODY] #1295855
09/06/12 09:11 AM
09/06/12 09:11 AM
W
W
the holes may be too big now I agree. I'll just buy a couple blades. I,m pretty sure the idle holes are clear we held the shop vac right up to the bit while drilling. and Ive inspected and ran it about 15 times, and it always had about the same adjustability.
its apart now, I will disassemble and blow it out just in case.
Re: need some carb tune advice [Re: We The People] #1295856
09/06/12 09:36 AM
09/06/12 09:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With the holes you move more air... you said you were
lean on idle so the holes will make it worse
Re: need some carb tune advice [Re: We The People] #1295857
09/06/12 11:13 AM
09/06/12 11:13 AM
mi
rbj Offline
rbj  Offline
mi
no need to buy new ones use a rivit in them.
Re: need some carb tune advice [Re: rbj] #1295858
09/06/12 01:08 PM
09/06/12 01:08 PM
W
W
thanks guys,
Re: need some carb tune advice [Re: We The People] #1295859
09/30/12 12:44 AM
09/30/12 12:44 AM
W
W
ressurecting Cause of my success in the fight of this problem.
The issue was due to TOO SMALL IFRs.
The throttle plate holes are plugged, the timing is now locked @32 with 5 degrees start retard,(which is the only setting it likes) The ifrs were .035 to start with and ended up @ .041. Now it starts up great cold or hot, idles nice @ 1000 and @ 800 in gear, with 8-9 inches of vac. the transfer slots are right where they should be, the idle mixture screws are out 2.25 turns (a little far but its cold out right now). I did some brake tests (no stumbles) and took it out for a quick rip. It will blaze the slicks from a jog with a quick 1/3 throttle stab.
Thanks Competition Wedge.....great cam
cant wait to get a wide band for summer time testing
Page 2 of 3 1 2 3
