1972 Radiator advice?... for an "odd vehicle"
#1295639
09/02/12 11:51 AM
09/02/12 11:51 AM
Posts: 392 Doniphan, Nebraska
Lmopar69
Doniphan, Nebraska
Hey folks, the 413 in my 72 has been running at about 215+ rollin down the highway. Replaced the thermostat, replaced the clutch fan, added "water wetter", etc.. etc... It has the original radiator in it and Im fairly certain its stopped up.
So, the question... Have a custom (yes it will probably have to be custom) aluminum radiator made or take the old one to a shop to be rodded out? I think "long term" the aluminum is the way to go.
Vehicle is my 1972 Rectrans Discoverer 25 motor home on a Dodge M350 Chassis with the stock 413 and Loadflite trans.
Laine.
NRCA Member
Re: 1972 Radiator advice?... for an "odd vehicle"
[Re: Lmopar69]
#1295640
09/02/12 11:53 AM
09/02/12 11:53 AM
Lmopar69
Doniphan, Nebraska
Oh yeah, the numbers on the radiator....
18398 is on the pass. side, then there is a tag soldered to the top drivers side that has 5626292. A "stock replacement" is an option too if I can find one!
So far, my searching has found nothing.
Laine.
NRCA Member
[Re: Lmopar69]
#1295641
09/02/12 11:55 AM
09/02/12 11:55 AM
RapidRobert
rodding out can & has worked but is risky. I'd myself go ahead & get a good new one for peace of mind (& it'll cool better)
[Re: RapidRobert]
#1295642
09/02/12 12:08 PM
09/02/12 12:08 PM
Lmopar69
Doniphan, Nebraska
Considering how hard this thing is to get in and out I tend to agree. If I go with a custom made aluminum I can have it made to fit a bit easier.
How can I find a OEM replacement? Ive been searching the numbers and cant find squat. Of course, searching the vehicle is nearly pointless too.
Laine.
NRCA Member
[Re: Lmopar69]
#1295645
09/02/12 01:05 PM
09/02/12 01:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hmm, original lasted 40 years, how long term do you think an aluminum one will be?
Did you attempt a flush at all?
[Re: Supercuda]
#1295646
09/02/12 02:36 PM
09/02/12 02:36 PM
Lmopar69
Doniphan, Nebraska
Didnt attempt a flush, it is a HUGE pain to get it in and out, so its a one shot one kill kinda deal.
I plan to make a couple calls on Tuesday morning and see how quick I can have something made, and how much it will cost. At the same time, the original will be at a radiator shop for a "repair" assessment.
Laine.
NRCA Member
[Re: Lmopar69]
#1295647
09/02/12 05:49 PM
09/02/12 05:49 PM
Posts: 4,808 Castlegar, BC, Canada
That AMC Guy
Any good rad shop should be able to recore the original rad as long as the tanks are good. Like Sheldon says, just get them to recore it with a modern, "high efficiency" core and call it a day. Probably be cheaper than an aluminum one and bolt right in no worries.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: Lmopar69]
#1295649
09/02/12 09:37 PM
09/02/12 09:37 PM
Posts: 22,727 Bitopia
jcc
Bitopia
Did you remove some of the duct tape on the grille used for qualifying? I would of the 3 options, I lean towards recoring, but I not convinced your overheating is the radiator, and especially if it is that big of deal to remove and replace in the first place, but that is spilled milk at this point.
[Re: jcc]
#1295651
09/02/12 11:22 PM
09/02/12 11:22 PM
Lmopar69
Doniphan, Nebraska
Ahhh! The duct tape! I knew I forgot something! Oh, and yes, it has a shroud. Im about 90% certain the radiator is the problem. This beast purrs like a kitten with an Edelbrock 750 on top and a K&N. Didnt burn 1/2 a quart of oil on a 1200 mile trip, and that was at 210+ degrees the entire way. I cant see any leaks anywhere, and it starts instantly just by looking at the key with a stern look. Really needs a set of headers on it though and some new exaust. Anyone got some big block headers layin around? Im all small blocks except this monster. The problem with the removal is hard to explain... however, I'll try. The radiator sits about 24" back from the grill. In that space there are two sheetmetal "boxes" about 14" x 12" basically behind the headlights. They are about 2" too narrow for the giant radiator to fit between. I removed one, but the other cant be removed. Well, the radiator mounting tabs are actually the problem. Other than that, it was simple. Remove two cross bars, 4 bolts and the hoses and it was pretty much loose. Although, the lower hose is not easy. Sits right over top of the cross member. It weighs 40lbs plus too. After removing it, looking inside, it looks "rough". Plenty of scale inside. I'll try to get a pic of this big old radiator and an under the hood pic of the motor home posted. Laine.
NRCA Member
[Re: SparkyRnD]
#1295658
12/10/14 07:42 PM
12/10/14 07:42 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Just wanted to chime in to say that thing is so COOL! I love it.
I was also wondering if 210 was too hot.
Facts are stubborn things.
