4 or 5 speed #1295034
09/01/12 12:41 PM
09/01/12 12:41 PM
florida dade
cesar perez Offline OP
florida dade
to all the stickshift guys what would be a better choice a 4spd or 5 speed for drag racing
Re: 4 or 5 speed [Re: cesar perez] #1295035
09/01/12 01:09 PM
09/01/12 01:09 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I have a 5-spd. Never get out of 4th in the 1/4 mile. Buddy had a Dakota with a 6-spd T-56. Again, never get past 4th
I don't think you want to be using an OD in a drag race. Even the 4 and 5 spd autos never get past the 1:1 gear
**Photobucket sucks**
Re: 4 or 5 speed [Re: 70Cuda383] #1295036
09/01/12 01:13 PM
09/01/12 01:13 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'd have to do the math again, but I think 6000 rpm in 4th gear is well over 100 mph (I want to say close to 115-120) in my truck. 3.92 gears, 27-28" tires.
Even I my old big block truck with a TKO and 4.56 gears, never got past 4th, and I was trapping at 107
Re: 4 or 5 speed [Re: 70Cuda383] #1295037
09/01/12 01:17 PM
09/01/12 01:17 PM
IN
ahy Offline
ahy  Offline
IN
For drag race only agree 4 speeds is plenty. If you want to street drive, an OD 5'th gear is really nice to get the revs, noise, wear and fuel consumption down though.
Re: 4 or 5 speed [Re: cesar perez] #1295038
09/01/12 03:23 PM
09/01/12 03:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have a tight torque curve and power level
you would want a 5 speed to keep it in the range
but if its wide the 4 speed.... look at pro stocks
EDIT
I'm not talking a OD 5 speed
Re: 4 or 5 speed [Re: cesar perez] #1295039
09/01/12 03:46 PM
09/01/12 03:46 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
As you can guess from my user name I have a 5-speed which is the best choice for me and how I use the car. For drag racing I would stick with a 4-speed. A well prepped 833 will shift faster and you will never get past 4 th. gear with any realistic rear end gears.
Re: 4 or 5 speed [Re: cesar perez] #1295040
09/01/12 06:13 PM
09/01/12 06:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Now are you talking 4 speed overdrive or a true 5 speed like a Richmond or Doug Nash If you have a heavy car or narrow torque curve go with a 5-speed.
Now if you have enough stones that the gear changes don't drag the engine down too much go with a 4 speed.
I like my 5-speed because the engine stays up in the happy range all the way down the track
Gus
64 Plymouth Savoy
Dana 60
Re: 4 or 5 speed [Re: fourgearsavoy] #1295041
09/05/12 11:51 AM
09/05/12 11:51 AM
New Haven County CT
Mr 5 Speed Offline
Mr 5 Speed  Offline
New Haven County CT
Couldn't agree more. GForce GF5-R 5 Speed and the clutch gets stepped everytime for me.
http://video.google.com/videoplay?docid=7528903995676743423&hl=en
Re: 4 or 5 speed [Re: Mr 5 Speed] #1295042
09/06/12 01:18 AM
09/06/12 01:18 AM
Kansas wishing I was in Ohio
SeanD Offline
SeanD  Offline
Re: 4 or 5 speed [Re: SeanD] #1295043
09/06/12 08:57 PM
09/06/12 08:57 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I run a Liberty prepped 833 in my Cuda. I really wish I could upgrade to a 5 speed. Even in a 9 second run, it seems like it takes forever for the engine to wind up for the next gear change. I like the 2.65 first gear, but I would like a little higher 2nd, a little lower 3rd, and one more in between.
[image][/image]
Re: 4 or 5 speed [Re: sgcuda] #1295044
09/06/12 09:38 PM
09/06/12 09:38 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
In my 2010 Challenger I never got out of 4th. 3.73 gear. I would think a 4 speed would be plenty.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 4 or 5 speed [Re: OhioMopar] #1295045
09/06/12 09:56 PM
09/06/12 09:56 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
Again, some of you guys are taking the question out of context. There's a big difference between a street type 5-speed where 4th = 1:1 and 5th = O.D., and a racing trans like a Liberty, Jerico, Nash, ETC that has a 1:1 5th gear and closer ratios in the 1-4 range
Re: 4 or 5 speed [Re: sgcuda] #1295046
09/07/12 09:31 PM
09/07/12 09:31 PM
Rittman Ohio
Rittman Ohio
These are my ratios, 3.28 2.13 1.57 1.24 1.00 and it feels perfect to me
and it may be up on the market come spring
Gus
64 Plymouth Savoy
Dana 60
Re: 4 or 5 speed [Re: EV2DEMON] #1295047
09/08/12 09:09 AM
09/08/12 09:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Right. I ASSuMEd the original poster was asking about "833 vs TKO" type transmissions, i.e. a 4-spd with 1:1 as final or a TKO with .64:1 as the final gear.
Didn't realize he was asking about a racing 5-spd that was close ratio with a final gear of 1:1
Question though, if your motor has a flat torque curve from 3000-6000 rpm, do you really need a close ratio gearbox? or would fewer gears, with less time spent "shifting" be better? or do you still see a benefit of running 5500-6000 rpm the whole pass vs 4500-6000?
