Re: Painting Fender Bolts- after installation
[Re: Fasbird]
#1295005
09/01/12 12:30 PM
09/01/12 12:30 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Mask the area around the bolt head off (I leave about a 1/32" gap around the bolt head) & airbrush the bolt head.. Done it many times, if done properly it's invisible...
[Re: Dave Watt]
#1295008
09/01/12 02:43 PM
09/01/12 02:43 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
What is the best suggestion as to how to paint the fender, trunk, exposed bolts after hanging the painted sheetmetal?
The best way? Install, align, and gap all of the panels before painting the car, that's how the factory did it on millions of Mopars, why mess with success?
Unfortunetely the "Chevy/Ford" menatallity is rampant among painters who seem to think the only way to paint a car is to blow it appart and shoot each panel on it's own on body bucks. Not only does this create a detail issue for Mopar purists (bolts, unpainted areas, overspray, etc.) it is also a good way to end up with painted panels that look different when installed because of the angle and application of the paint, especially on panel edges and with metallic paints.
That said, the air brush method makes the most sense to correct it, hopefully the artist is good enough to pull off a believable finished look. Also, if you want good paint adhesion blast those plated bolts (those are aftermarket bolts right?) so the paint will get a better grip.
[Re: AAR#2]
#1295011
09/01/12 11:28 PM
09/01/12 11:28 PM
Posts: 4,912 The Dark Side
Fasbird
The Dark Side
Thanks for thew tips so far guys. wasn't really looking for the debate of how the car SHOULD have been painted, just a few "constructive tips". 1cuda...thanks. yep, the paint turned out fantastic. Can you imagine this was painted back in '04? Except for a little dust, it still looks flawless. I'll try the plastic baggy trick. I think when I used the t-shirt, I didn't give enough drying time for the paint. I'll paint a few bolts and let 'em dry for a couple days. If any more techniques, please feel free to mention them.
[Re: ScottSmith_Harms]
#1295015
09/01/12 11:40 PM
09/01/12 11:40 PM
Fasbird
The Dark Side
Your car looks fantastic, please don't take my comments the wrong way, I wasn't trying to be negative towards you or your car, it was more of a comment for the guys reading this thread who havn't had thier cars painted yet to consider before turning the painter loose on thier cars.
Just pokin a little fun at ya' Scott.
[Re: Fasbird]
#1295016
09/02/12 10:38 PM
09/02/12 10:38 PM
Posts: 4,046 Minnesota
72blubird
Minnesota
Since they mixed the paint for you why not see if someone local can put paint in a can. Then you can mask and paint.
What was I thinking....
[Re: Fasbird]
#1295018
09/03/12 12:41 PM
09/03/12 12:41 PM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
Did you just join the board yesterday ?? This is Moparts , you'll always be TOLD what to do , you may even have your questioned actually answered ...
