Painting Fender Bolts- after installation #1295003
09/01/12 11:23 AM
09/01/12 11:23 AM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Ok, here is a question for the Master Restorers in Moparts Land. What is the best suggestion as to how to paint the fender, trunk, exposed bolts after hanging the painted sheetmetal? I an trying to avoid the "marred look" after putting a socket over the painted bolt. I heard to remove some bolts, stick through a piece of cardboard and paint. When dry, use a t-shirt, etc. between the socket and bolthead when re-installing the bolt. I tried this, but still managed to mar the hex high spots on the bolt. Any and all tips are welcome!!!
Thanks guys!!!!
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295004
09/01/12 11:24 AM
09/01/12 11:24 AM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
front fender
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295005
09/01/12 12:30 PM
09/01/12 12:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Mask the area around the bolt head off (I leave about a 1/32" gap around the bolt head) & airbrush the bolt head.. Done it many times, if done properly it's invisible...
Re: Painting Fender Bolts- after installation [Re: 1_WILD_RT] #1295006
09/01/12 01:39 PM
09/01/12 01:39 PM
N.E. OHIO
P
polara426 Offline
polara426  Offline
P
N.E. OHIO
I think the air brush method described would work best but I had my paint shop mix 4 ounces of single stage paint in color and I used it to touchup nicks worked great.I also use plastic wrap when assembling painted bolts.
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295007
09/01/12 01:42 PM
09/01/12 01:42 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Hey Gary, the paint looks nice.
I used masking tape around each washer. Sprayed some etching primer on the bolt/washer. Using a small amount of paint on a lid or in a cup, mixed in a little reducer, then used a hobby paint brush on each of them. It's time consuming but with the reducer it will flow and smooth out when drying. It might take an extra coat to get full coverage.
Re: Painting Fender Bolts- after installation [Re: Dave Watt] #1295008
09/01/12 02:43 PM
09/01/12 02:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The best way? Install, align, and gap all of the panels before painting the car, that's how the factory did it on millions of Mopars, why mess with success?
Unfortunetely the "Chevy/Ford" menatallity is rampant among painters who seem to think the only way to paint a car is to blow it appart and shoot each panel on it's own on body bucks. Not only does this create a detail issue for Mopar purists (bolts, unpainted areas, overspray, etc.) it is also a good way to end up with painted panels that look different when installed because of the angle and application of the paint, especially on panel edges and with metallic paints.
That said, the air brush method makes the most sense to correct it, hopefully the artist is good enough to pull off a believable finished look. Also, if you want good paint adhesion blast those plated bolts (those are aftermarket bolts right?) so the paint will get a better grip.
Re: Painting Fender Bolts- after installation [Re: ScottSmith_Harms] #1295009
09/01/12 07:34 PM
09/01/12 07:34 PM
western australia
1cuda Offline
1cuda  Offline
western australia
i also agree with scott on the factory procedure -only because if done like the factory this question wouldn`t arise. BUT...in looking at the paintwork which looks amazing i can see the show benefits of painting things apart-we do it when customers want show type finish-what do we do for the bolts-get yourself another set of new bolts-blast them and dip them in a good thin etching primer then spray them with the same paint color-hopefully direct gloss and not clear over base. let the paint harden and get yourself the snap-on sockets that are lined in rubber to prevent paint chippping-i`m sure you can get 7/16 1/2 and 9/16. that will cover most of your bolts.
good luck
all the best
frank.
Re: Painting Fender Bolts- after installation [Re: 1cuda] #1295010
09/01/12 10:18 PM
09/01/12 10:18 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Met wrenches turn bolts and nuts by indexing to the flats rather than the traditional socket/wrench that point loads. Couple the use of them with zip lock bag plastic and you have a fighting chance.
Good luck with the issue
Re: Painting Fender Bolts- after installation [Re: AAR#2] #1295011
09/01/12 11:28 PM
09/01/12 11:28 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Thanks for thew tips so far guys. wasn't really looking for the debate of how the car SHOULD have been painted, just a few "constructive tips".
1cuda...thanks. yep, the paint turned out fantastic. Can you imagine this was painted back in '04? Except for a little dust, it still looks flawless. I'll try the plastic baggy trick. I think when I used the t-shirt, I didn't give enough drying time for the paint. I'll paint a few bolts and let 'em dry for a couple days.
If any more techniques, please feel free to mention them.
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295012
09/01/12 11:29 PM
09/01/12 11:29 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
nudder.
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295013
09/01/12 11:36 PM
09/01/12 11:36 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
when it first came home in '05.
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295014
09/01/12 11:39 PM
09/01/12 11:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Your car looks fantastic, please don't take my comments the wrong way, I wasn't trying to be negative towards you or your car, it was more of a comment for the guys reading this thread who havn't had thier cars painted yet to consider before turning the painter loose on thier cars.
Re: Painting Fender Bolts- after installation [Re: ScottSmith_Harms] #1295015
09/01/12 11:40 PM
09/01/12 11:40 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Just pokin a little fun at ya' Scott.
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295016
09/02/12 10:38 PM
09/02/12 10:38 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Since they mixed the paint for you why not see if someone local can put paint in a can. Then you can mask and paint.
What was I thinking....
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295017
09/03/12 12:35 PM
09/03/12 12:35 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Gar,
You going back stock with it this time?
I seem to remember you were headed towards a resto mod cruiser sorta thing before .
IF so, go stainless bolts = no paint needed.
I've done the mask and airbrush method with decent results.
Never tried the plastic socket insert method before , although it sounds plausible
Re: Painting Fender Bolts- after installation [Re: Fasbird] #1295018
09/03/12 12:41 PM
09/03/12 12:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you just join the board yesterday ?? This is Moparts , you'll always be TOLD what to do , you may even have your questioned actually answered ...
Re: Painting Fender Bolts- after installation [Re: JohnRR] #1295019
09/03/12 01:02 PM
09/03/12 01:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
wheres your answer to his question John?
Re: Painting Fender Bolts- after installation [Re: ScottSmith_Harms] #1295020
09/03/12 01:25 PM
09/03/12 01:25 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
They do make sockets with plastic inserts in them, which will prevent the scratching/marring of the paint.........
Admiration For Multiple Carburetor Vehicles...
Re: Painting Fender Bolts- after installation [Re: Stewpar] #1295021
09/03/12 02:42 PM
09/03/12 02:42 PM
MO
cdp Offline
cdp  Offline
MO
I'm in the same boat as the original poster. Just got my RR back from paint, only to find out that the painter didn't paint the fenderbolts, etc, in place.
I have to do it all on my own.
One method I had read years ago, was to paint them separately, then slide them into a toaster oven to harden the paint.
