70 CUDA MASTER CYLINDER #1294949
09/01/12 02:48 AM
09/01/12 02:48 AM
california santa clarita
moparpete22 Offline OP
LOOKING FOR AN AFTER MARKET PIECE WITH THE SAME TYPE OF LOOK AS AN ORIG. THE ORIGINALS ARE JUST TO MUCH MONEY. DONT CAR ABOUT THE NUMBERS JUST WOULD LIKE IT TO LOOK AS CLOSE AS AS POSS.
I SEE SOME PAINTED BLACK AND SOME NOT?
THANK YOU, PETE
Re: 70 CUDA MASTER CYLINDER [Re: moparpete22] #1294950
09/01/12 04:05 AM
09/01/12 04:05 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Seeing that you have a post about masters and boosters...either use Dewey for the booster rebuild or purchase a Cardone unit from Autozone/Napa/CarQuest or any parts supplier who carries Cardone, including SummitRacing.com they carry the Cardone line of new/remanufactured OEM parts
Here's the list of 70 340 E body power brake set ups for either disc or drum
Mike
Re: 70 CUDA MASTER CYLINDER [Re: moparpete22] #1294951
09/01/12 10:21 AM
09/01/12 10:21 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Your choices are either to use a '67-70 B body type disc brake master cylinder or the '71-'75 Mopar "one size fits all" master cylinder. The B body one has a 1-1/8" bore, the '71 up style has a 1-1/32" bore. The OEM master had a 1" bore. The 1-1/8" one, which can be purchased aftermarket as Raybestos MC36283 has a closer look to original as it has the "thermometer" style geometry on the front. The other one I mentioned is Raybestos MC36307. I've used both styles on my '70 and '71 PDB Challengers and both work, the 36283 has a harder pedal and the brakes are a little sensitive, so maybe the 36307 is a bit better functionally, but both work.
Disc brake masters should be painted semi gloss black.
Re: 70 CUDA MASTER CYLINDER [Re: Mastershake340] #1294952
09/01/12 10:56 AM
09/01/12 10:56 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
white post restorations also does nice work on the boosters as well.
Super Commando
Re: 70 CUDA MASTER CYLINDER [Re: 70plymA34] #1294953
09/01/12 11:12 AM
09/01/12 11:12 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Ya the 70E only Bendix units can be big bucks. If your just wanting a good driver unit that looks correct then the cardone units that Dayclona listed are a good way to go. If you look at alot of their's you'll see that they are actually Ford boosters. Ford used the same Bendix unit in millions of cars. You can see where they cut off the 2 master cylinder "Ford" studs and installed the 4 "Mopar" studs. Still works just fine.
Bendix units are black.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 70 CUDA MASTER CYLINDER [Re: moparpete22] #1294954
09/01/12 12:13 PM
09/01/12 12:13 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have used this master on a few cars. Looks similar and is reasonably priced. http://www.rockauto.com/catalog/moreinfo.php?pk=309076
Re: 70 CUDA MASTER CYLINDER [Re: Azzkikrcuda] #1294955
09/01/12 01:12 PM
09/01/12 01:12 PM
Crook County, ILL
Crook County, ILL
That is the MC36283 I mentioned previously.
Re: 70 CUDA MASTER CYLINDER [Re: Mastershake340] #1294956
09/01/12 01:29 PM
09/01/12 01:29 PM
Thank you all for all the great info. i appreciate it. pete
Re: 70 CUDA MASTER CYLINDER [Re: Azzkikrcuda] #1294957
09/02/12 02:09 AM
09/02/12 02:09 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
But don't believe the underside photo with the made in USA stamp. I ordered one a few weeks back and it was manufactured in China.
