Re: 70 CUDA MASTER CYLINDER
[Re: 70plymA34]
#1294953
09/01/12 11:12 AM
09/01/12 11:12 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Ya the 70E only Bendix units can be big bucks. If your just wanting a good driver unit that looks correct then the cardone units that Dayclona listed are a good way to go. If you look at alot of their's you'll see that they are actually Ford boosters. Ford used the same Bendix unit in millions of cars. You can see where they cut off the 2 master cylinder "Ford" studs and installed the 4 "Mopar" studs. Still works just fine. Bendix units are black.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
