'67 big block dual snorkel air cleaner I.D. #1294666
08/31/12 05:00 PM
08/31/12 05:00 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I just scored a '67 dual snorkel air cleaner. It has the original base which fits AVS type Carter… at least it appears and was reported to be the original base - sure looks like it is.
Anyway, what is the deal with '67 b-body air cleaners? I have had one other '67 dual snorkel air cleaner as well which was just the same and had an AVS base on it. It has the right indents and indent positions etc however it and my current assembly are 18" across vs 17" typically found on '68 and '69 type dual snorkels.
I have heard different things…. Did big block C-Body cars use the same overall looking air cleaner in '67 but with an 18" dia and a larger throat base? Did b-body big blocks look the same except with a 17" diameter and an AFB base? Or…... did they both use this 18" type? If so, why would the bases fit AVS? I know they did not use AVS's until 1968 and the AFB cutout is smaller in diameter. Like I said, both of the units I have had would fit an AVS.
Is there such a thing as a 17" 67 big block dual snorkel with an AFB sized base?
I have also have this question out to Nick at Nicks Garage. His site shows what appears to be two different parts with the same overall look. Can't be determined if one is smaller in diameter that the other or what the base diameter is of each.
Re: '67 big block dual snorkel air cleaner I.D. [Re: 70mopes] #1294667
08/31/12 05:46 PM
08/31/12 05:46 PM
Arizona
az426john Offline
az426john  Offline
Arizona
My 67 GTX came with the 18" round air cleaner so I cannot answer your question about the diameters, but the carburator opening in the baseplate should measure 4-1/4 inches in diameter for the AFB carburator. AVS carbs were not used in 1967 to the best of my knowledge.
Re: '67 big block dual snorkel air cleaner I.D. [Re: az426john] #1294668
08/31/12 05:51 PM
08/31/12 05:51 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You are correct , 68 was first year for the AVS and the 68 base will fit the 67 top.
Re: '67 big block dual snorkel air cleaner I.D. [Re: az426john] #1294669
08/31/12 05:53 PM
08/31/12 05:53 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I agree. Seems weird that both my 18" '67 dual snorkels would have a base with the larger dia cutout. Doesn't make any sense since most if not all follow on dual snorkel applications (68 up) appear to use 17 inch diameter dual snorkel air cleaners and bases. What air cleaner would use an 18 inch base with an AVS sized cutout....hmmmm.
Re: '67 big block dual snorkel air cleaner I.D. [Re: JohnRR] #1294670
08/31/12 06:03 PM
08/31/12 06:03 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
John
The '68 base (and '69) does not fit on the '67. They are different diameters. '68 has a 17 inch outer diameter and '67 an 18 inch outer diameter. I don't know at this point where 18 inch air cleaner bases with AVS sized cutouts would have been used. Anybody know the answer to this?
Re: '67 big block dual snorkel air cleaner I.D. [Re: JohnRR] #1294671
08/31/12 06:04 PM
08/31/12 06:04 PM
Arizona
az426john Offline
az426john  Offline
Arizona
John,
Right you are as usual. I ran an AVS on my 67 GTX until I could find the correct AFB and the AVS - AFB baseplates in this case were interchangable.
Re: '67 big block dual snorkel air cleaner I.D. [Re: az426john] #1294672
08/31/12 06:22 PM
08/31/12 06:22 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Here is the air cleaner in question. The AVS base wouldn't be original as this is definitely the '67 GTX-R/T air cleaner.
I'll have to measure my '68 Barracuda unsilenced one as it is the same as the '67 GTX shape but of course uses an AVS base.
Another thought is that the 361-383 2V base has the same opening as the AFB but I don't know the diameter of the air cleaners overall compared to a 4-bbl one.
Re: '67 big block dual snorkel air cleaner I.D. [Re: NicksGarage] #1294673
08/31/12 10:26 PM
08/31/12 10:26 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I measured my '68 383-S air cleaner and it is 18" across.
Anyone have a big block 2-bbl air cleaner they can measure?
Re: '67 big block dual snorkel air cleaner I.D. [Re: NicksGarage] #1294674
09/03/12 11:54 AM
09/03/12 11:54 AM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
Weren't some of the '67 air cleaners and/or the bases left over and then used on early '68 models? I don't know about the different carb openings though.
Re: '67 big block dual snorkel air cleaner I.D. [Re: markrr] #1294675
09/03/12 12:35 PM
09/03/12 12:35 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Yes, on the unsilenced ones. They used the big one for a while in 1968 until they came out with the smaller version that was also used in 1969. The base plate changed to fit the larger AVS carburetor.
Re: '67 big block dual snorkel air cleaner I.D. [Re: NicksGarage] #1294676
09/04/12 02:25 PM
09/04/12 02:25 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Can someone with a '68 and '69 dual snorkel measure the outside diameter?
Re: '67 big block dual snorkel air cleaner I.D. [Re: NicksGarage] #1294677
09/04/12 02:35 PM
09/04/12 02:35 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
17 inches.
Re: '67 big block dual snorkel air cleaner I.D. [Re: 70mopes] #1294678
09/04/12 04:24 PM
09/04/12 04:24 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
17 inches.
Thanks.
Also, do any '67 cars come with a 4-bbl carb that isn't a Carter AFB?
Re: '67 big block dual snorkel air cleaner I.D. [Re: NicksGarage] #1294679
09/04/12 05:35 PM
09/04/12 05:35 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Answer: Not according to the service manual. Additionally, I have never seen any.
Scott @ Harms will know more I am sure.
Re: '67 big block dual snorkel air cleaner I.D. [Re: az426john] #1294680
09/04/12 05:40 PM
09/04/12 05:40 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
According to this article, c-body 440's did.
http://www.moparmusclemagazine.com/parts...INTERSTITIAL_15
Re: '67 big block dual snorkel air cleaner I.D. [Re: 70mopes] #1294681
09/04/12 08:32 PM
09/04/12 08:32 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I guess it could be true. But they are not listed in the Chrysler Service Manual I have.
Re: '67 big block dual snorkel air cleaner I.D. [Re: markrr] #1294682
09/05/12 12:36 AM
09/05/12 12:36 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Not too sure about that, but 1968 California cars used the 67 air cleaners for N97 noise reduction requirements. (and turned down exhaust tips)
Re: '67 big block dual snorkel air cleaner I.D. [Re: Bull1tt] #1294683
09/05/12 12:56 AM
09/05/12 12:56 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
BS - continued bad info & rumors.
What proof does anyone have that (and turned down exhaust tips) was an issue on anythig other than '70 HEMI b-bodies and '70-'71 440+6 & HEMI e-bodies?
Re: '67 big block dual snorkel air cleaner I.D. [Re: 70mopes] #1294684
09/05/12 01:08 AM
09/05/12 01:08 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Here's a period road test showing a '67 Imperial with the air cleaner off and a Holley carb is there. http://www.imperialclub.com/Articles/67Comfort/index.htm
This 1985 article one shows the single snorkel air cleaner with pie tin. Page 5. http://www.imperialclub.com/Articles/67NotChrysler/index.htm
Re: '67 big block dual snorkel air cleaner I.D. [Re: NicksGarage] #1294685
09/05/12 06:20 AM
09/05/12 06:20 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
So, I figured, I'll look thru the '67 Parts Catalog & find the answer - WRONG!!
CARBURETOR 14-30-1
The 440 (non-HP) with C.A.P. c-body & Imperial carb was a Carter AFB.
The 440 (non-HP) w/o C.A.P. c-body & Imperial carb was a HOLLEY.
All other 383/440 4bbl engines are Carter AFB.
Air Cleaner FILTER 14-29-6
all 383/440 with C.A.P. = 2463 985 also in '66 Catalog
all 383/440 w/o C.A.P. = 2402 677 also in '66, '68 & '69 Catalogs
Air Cleaner Base RETAINER 14-29-9
a-body 383 (no snorkel) = 2463 959
b-body 440HP (no snorkel) = 2863 992
b & c-body 440HP (2 snorkels) = 2899 410
c-body & Imp 440 (non-HP) with C.A.P. = 2806 332
c-body & Imp 440 (non-HP) w/o C.A.P. = 2843 058 also in '68 Catalog
* for some reason they list all 383s as part #2402 678 (no 2bbl/4bbl difference)
Air Cleaner Lid COVER 14-29-7 14 different BB part numbers
let's try 440 (all part numbers listed are 440 ONLY)
b-body 440HP (no snorkel) = 2863 986
b & c-body 440HP with C.A.P.(2 snorkels) = 2843 068
b & c-body 440HP w/o C.A.P.(2 snorkels) = 2843 069
c-body 440 Station Wagon & Police with C.A.P. (2 snorkels) = 2843 053 also in '68 Catalog
c-body 440 Station Wagon & Police w/o C.A.P. (2 snorkels) = 2843 055
c-body & Imp with C.A.P. (single snorkel) = 2806 320 also in '68 Catalog
c-body & Imp w/o C.A.P. (single snorkel) = 2806 318
Since the RETAINER, COVER, & FILTER are affected by C.A.P., I believe there is a difference other than the breather hose. filter seat diameter/height?
I'll check the '66 & '68 catalogs to see which parts were used elsewhere. the '66 catalog lists most of the air cleaners as assemblies
