Magnum valve spring question #1294106
08/30/12 10:33 AM
08/30/12 10:33 AM
wisconsin
1BAD68 Offline OP
1BAD68  Offline OP
wisconsin
I have a set of 318 magnum heads to install on my LA 318, got everything set to go but not sure about the springs.
Current cam is a Comp Cams .440 lift. According to what I've read, that will change to .469 with the magnums 1.6 rockers.
Will the stock magnum valve springs work with this? I can't find specs for those springs.
Re: Magnum valve spring question [Re: 1BAD68] #1294107
08/30/12 01:05 PM
08/30/12 01:05 PM
dogdays Offline
dogdays  Offline
Patrick, where are you?
Comp 901s will work.
R.
Re: Magnum valve spring question [Re: dogdays] #1294108
08/30/12 02:00 PM
08/30/12 02:00 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
Comp 901s will work if you machine the head so they fit.
R.
fixed
more info on this here-
http://www.bigblockranger.com/Magnum.html
Re: Magnum valve spring question [Re: 65rbdodge] #1294109
08/30/12 02:07 PM
08/30/12 02:07 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
No. they will not work
stock springs are barely enough for a stock cam. I can take them and compress them a little bit by hand, that's how weak they are.
they'll PROBABLY accept the lift though, as they don't run into clearance issues until .500 lift, but again, you'll float the valves long before you hit 5,000 rpm.
I would consider running the Hughes 1110 springs or something similar. that's a good all-around spring that works for a lot of cams.
**Photobucket sucks**
Re: Magnum valve spring question [Re: 65rbdodge] #1294110
08/30/12 02:12 PM
08/30/12 02:12 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Several sources for a drop in valve spring,Hughes,MP,Bullet cams. 1.437OD is all that will fit without cutting the spring seats. Hughes has the springs and retainers that will work.
Re: Magnum valve spring question [Re: goldmember] #1294111
08/30/12 03:47 PM
08/30/12 03:47 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
if you are really cheap like me you could get some springs/retainers from a GM 3.1 or 3.4 motor in the junkyard. with the lift you have, they will probably be at their limit. here they are on my heads, the 4 closest in the pic are the stock magnum springs, the other 4 are from a 3.4 motor. the redrilling jig i made on the other head too.
Re: Magnum valve spring question [Re: 65rbdodge] #1294112
08/30/12 11:08 PM
08/30/12 11:08 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
stock Mag springs = Wimpy! Made for low RPM truck torque output, not high RPM horsepower.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Magnum valve spring question [Re: GO_Fish] #1294113
08/31/12 09:45 AM
08/31/12 09:45 AM
wisconsin
1BAD68 Offline OP
1BAD68  Offline OP
wisconsin
So these will work?... http://www.jegs.com/i/Comp-Cams/249/901-16/10002/-1
I assume I'll need retainers too?
Re: Magnum valve spring question [Re: dogdays] #1294114
08/31/12 10:25 AM
08/31/12 10:25 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
R.
https://board.moparts.org/ubbthreads/show...rue#Post3134434
ask and ye shall receive.
comp 901's have a ~1.1" coil bind height. you'll get about 1.6-1.64" install height with the proper retainers, so if you want to leave .060 before coil bind, that'll leave you with .440-.480" max lift, depending on install height.
for this moderate lift, I'd use either the GM3100 springs and retainers, or for about the same price, hughes #1110 springs and either used 2.2L retainers or hughes retainers. that'll give you ~.040-.060" more lift capacity than the the GM3100 springs, for about the same price (if you're not junkyard scrounging)
2017 Grand Cherokee Overland
Re: Magnum valve spring question [Re: patrick] #1294115
08/31/12 10:54 AM
08/31/12 10:54 AM
wisconsin
1BAD68 Offline OP
1BAD68  Offline OP
wisconsin
Is any machining needed to make the Hughes 1110 springs fit? I noticed they have dampers.
Re: Magnum valve spring question [Re: 1BAD68] #1294116
08/31/12 01:06 PM
08/31/12 01:06 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
nope, they dropped right on my magnum heads.
Re: Magnum valve spring question [Re: patrick] #1294117
09/03/12 02:06 PM
09/03/12 02:06 PM
dogdays Offline
dogdays  Offline
Anyone have a retainer for the beehive springs and 3/8" stems?
Thanks,
R.
