Engine weight #1294073
08/30/12 05:13 AM
08/30/12 05:13 AM
North America
2002bluert Offline OP
North America
Not sure if this has been asked before, But I was wondering if you can get the weight of a 440 down to the weight of a stock small block. By changing to aluminum heads, intake, water pump and so on. Seems small block cars handle better without all the weight out front so just wondering if its possible and if anyone has weighed the difference. Thanks
Re: Engine weight [Re: 2002bluert] #1294074
08/30/12 01:03 PM
08/30/12 01:03 PM
AndyF Offline
AndyF  Offline
Yes, it is fairly easy to do that. I covered the subject in my B-body book.
This big block only weighs 490 lbs. It could be made even lighter with a little more work (money).
Re: Engine weight [Re: AndyF] #1294075
08/30/12 05:11 PM
08/30/12 05:11 PM
AndyF Offline
AndyF  Offline
This SB is 450 lbs, but it has aluminum heads and intake. It also has lightweight internals. A stock SB with all cast iron parts is about 550 lbs. Just depends if you include exhaust manifolds, flywheel, etc.
But bottom line, it is easy to build a BB engine that weighs less than a stone stock SB. A stroker big-block should be lighter than a stock big-block due to the lighter rotating assembly.
Re: Engine weight [Re: AndyF] #1294076
08/30/12 07:15 PM
08/30/12 07:15 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
Not to hi-jacko the thread but I just ordered your book today. I hear its a good read. !!
Re: Engine weight [Re: beatgoeson] #1294077
08/31/12 03:23 AM
08/31/12 03:23 AM
North America
North America
Thanks, ordered both your books off ebay today myself.
Re: Engine weight [Re: AndyF] #1294078
08/31/12 07:42 AM
08/31/12 07:42 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Could you provide weight for a HEMI? Stock,vs. Aluminum heads/waterpump vs. all aluminum? Also, what is the title of your book?
Lynn
Re: Engine weight [Re: Hemi ragtop] #1294079
08/31/12 10:58 AM
08/31/12 10:58 AM
Charleston, SC
bronco9588 Offline
bronco9588  Offline
Charleston, SC
Is the 490# bb as pictured or just the casting. I am trying to estimate freight and I have not a scale able to weigh that much.
'73 Charger Petty Blue, Black Vinyl, and Gill Slits 727 torque-flight 400 BB Chrysler 8 3/4 rear
Re: Engine weight [Re: bronco9588] #1294080
08/31/12 11:52 AM
08/31/12 11:52 AM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
I have heard that a stock 440 is only 50 lbs heavier than a stock slant six. Anybody know if it is true or not ?
Re: Engine weight [Re: Darter6] #1294081
08/31/12 06:57 PM
08/31/12 06:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't know about that. While slants are fat for what they are, stock front torsion bars on slant cars are MUCH less beefy that stock torsion bars on BB cars. I would say it's probably more like a slant would be near 50lbs to a stock SB.
Re: Engine weight [Re: DaytonaTurbo] #1294082
08/31/12 07:17 PM
08/31/12 07:17 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
According to :
http://www.moparts.org/Tech/Archive/motor/21.html
Engine Weight's
Slant Six 475
273-340 "A" V8 525
360 "A" 550
361-383-400 V8 620
413-426W-440 V8 670
Street Hemi 765
INDY MAXX AL engine - 528CI - 470 lbs assembled
Re: Engine weight [Re: Hemi ragtop] #1294083
08/31/12 09:41 PM
08/31/12 09:41 PM
AndyF Offline
AndyF  Offline
This Hemi is 570 lbs. It is a 528 inch crate Hemi from Mopar Performance so it has aluminum heads and a dual plane intake.
