Re: burn out Q with M/T drag radials
[Re: 67dodge67]
#1294058
08/30/12 07:42 PM
08/30/12 07:42 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I assume you have low band apply on your valve body, just wondered, as you said you burn out in 1st gear. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 67dodge67]
#1294060
08/31/12 10:51 AM
08/31/12 10:51 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
A little trick we are doing. Large first burnout as mentioned. Then just a quick burnout just to start to get smoke after the first break in burn out. Roll on out until it bites, but continue rolling up past the starting line (no longer spinning obviously) but picking up all of the fresh glue further out. My buddy is running consistant 7.60's in the quarter w/1.2 60's in his 68 Chevelle.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1294061
08/31/12 11:04 AM
08/31/12 11:04 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
not allowed to go past the tree at our local tracks.....only the "big boys" can do that.
[Re: Mr.Yuck]
#1294062
08/31/12 12:34 PM
08/31/12 12:34 PM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
I just put MT ET Street radials on my truck for the first time last week, so I'm still learning myself. I ended up at 22psi, did a second gear burnout at 6000rpm for about 3 seconds and let it coast out and hook. It made all 8 passes between 1.552 and 1.560 sixty foot. On the 40 mile drive home I noticed some vibration...after checking the balance I found that the wheels had turned about 4 inches in the tires! I guess it's either time for rim screws, or maybe a little more air pressure.
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
[Re: lowbudget]
#1294064
08/31/12 01:41 PM
08/31/12 01:41 PM
6PKRTSE
Motor City
Beadlocks preferred (on high horse power applications). Even with glue one of my other buddies spins the tire on the rim about 1" to 1-1/2" almost every pass.
[Re: 6PKRTSE]
#1294065
08/31/12 04:42 PM
08/31/12 04:42 PM
DconD100
Colo Springs, CO
What the heck kind of glue sticks to aluminum and rubber? I love the idea of not having to drill holes in my Convopros though! Looks like I'm only turning the wheel about a half inch in the tire per pass.
