Tuning info when adding a 1 in carb spacer? #1293923
08/29/12 07:45 PM
08/29/12 07:45 PM
Ohio
moparjoe360.4 Offline OP
Ohio
I'm thinking of adding the 1 inch carb spacer I bought at the beginning of the race season. My question is how much will it effect my tune, will I need to make jet changes? I run a mild 360 with a .454 lift hydraulic cam Edelbrock Preformer 318/360 and a 650 spread bore double pumper Holley. I need it ready and still consistent for Norwalk
Re: Tuning info when adding a 1 in carb spacer? [Re: moparjoe360.4] #1293924
08/29/12 11:23 PM
08/29/12 11:23 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Go up 4 squirter sizes and 10 jet sizes...
Just Kidding!
We all know that every combination is different and has different needs. A test and tune is the only way to see what the spacer does/changes your tune. If your car is currently consistent, leave it alone for Norwalk...
Re: Tuning info when adding a 1 in carb spacer? [Re: 340_Dart] #1293925
08/30/12 12:16 AM
08/30/12 12:16 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
The answer lies in dyno and track testing with wideband o2,Way to many variables to accept an internet answer as gospel.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Tuning info when adding a 1 in carb spacer? [Re: BIGSPEED] #1293926
08/30/12 07:06 AM
08/30/12 07:06 AM
Washington
skrews Offline
skrews  Offline
Washington
X2
Re: Tuning info when adding a 1 in carb spacer? [Re: moparjoe360.4] #1293927
08/30/12 09:38 AM
08/30/12 09:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Cant say but it would matter if its a 4 hole or a
open one... the 4 hole keeps the velocity up in the
carb with a small gain in plenum volume where the open
one tends to just increase plenum volume
Re: Tuning info when adding a 1 in carb spacer? [Re: moparjoe360.4] #1293928
08/30/12 11:31 AM
08/30/12 11:31 AM
New York
polyspheric Online content
polyspheric  Online Content
New York
In general:
Richer idle mixture
More PVCR
May want 2-4° more idle spark
Boffin Emeritus
Re: Tuning info when adding a 1 in carb spacer? [Re: polyspheric] #1293929
08/30/12 06:41 PM
08/30/12 06:41 PM
Ohio
Ohio
I know I can't base it all off what someone else says, I'm just lookin to see what everyone's opinion is n go from there. The spacer is an open one. I use to run a square bore carb on the same intake with a 1 inch adapter and it seemed to have a little more topend pull. That's why I'm kickin around the idea of adding it before Norwalk
Re: Tuning info when adding a 1 in carb spacer? [Re: polyspheric] #1293930
08/31/12 11:46 PM
08/31/12 11:46 PM
Az
Crizila Offline
Crizila  Offline
Az
In general:
Richer idle mixture
More PVCR
and maybe a size larger on the squirters.
Fastest 300
