440 dipstick length #1293253
08/28/12 10:52 PM
08/28/12 10:52 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
can anyone tell me what the correct length of the dipstick needs to be. i bought i new one from summit, installed it, put 5 quarts of oil in the motor. I pull out the dip stick, and it is bone dry. my oil pan appears to be stock. Any help would be greatly appreciated, thanks.
Re: 440 dipstick length [Re: mkbubs] #1293254
08/28/12 11:29 PM
08/28/12 11:29 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Is the tube fully seat in the block. Next what year motor. Do you have the old stick.There is a diffence between some years for both dip stick and dip stick tubes. If you know for sure you have a certain amount of oil in the pan and that is correct then just mark your dipstick and go by that measurement.
1971 HEMI E BODY REGISTRY
Re: 440 dipstick length [Re: mkbubs] #1293255
08/29/12 12:02 AM
08/29/12 12:02 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Don't know if this will help but.......
1970 GTX 440 4bbl original oil dipstick is 23 inches long from tip to seat flange [where it rests on top of tube after inserting].
Bottom of stick to "add" line is 1 7/8"
Bottom of stick to "full" line is 2 1/2"
Re: 440 dipstick length [Re: mkbubs] #1293256
08/29/12 08:46 AM
08/29/12 08:46 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Sounds like you don't know what oil pan you have , crawl under it and look for a number , take a picture if it has no number.
A link to the dipstick you bought will help , also the length of the dipstick is useless without knowing the tube length also.
Did the dipstick you bought come with a tube ? Did you use it or stick the dipstick you bought into the tube that was already in your engine ?
Re: 440 dipstick length [Re: JohnRR] #1293257
08/29/12 09:30 AM
08/29/12 09:30 AM
Indiana
Mrbill69 Offline
Mrbill69  Offline
Indiana
Bought a chrome one to replace my damaged one. 3-1/2 qts would bring it to the full mark. I just drained it good, put in 6 qts of oil, ran it then made my own marks.
66 satellite conv w/413, cam & headers, 3.55 gears. 89 Dodge w150 4x4 318 Tbi. Opec's friend 72 Imperial coupe
Re: 440 dipstick length [Re: mkbubs] #1293258
08/29/12 11:34 AM
08/29/12 11:34 AM
Yes see what pan you have which will tell you if you need more oil or a longer dipstick. If you have a regular BB shallow "center sump" type pan I'd put 4 qts in on a level surface and either get the correct dipstick or a longer universal one & remark it
