4 speed to automatic conversion #1293054
08/28/12 05:36 PM
08/28/12 05:36 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
What parts can be reused, and what parts cannot? I am thinking transmission mount, speedo cable, speedo gear, transmission crossmember, driveshaft and yolk, can all be re-used. Am I missing anything? Is there anything else that would have to be changed?
Re: 4 speed to automatic conversion [Re: mshred] #1293055
08/28/12 06:19 PM
08/28/12 06:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Which trans ? A body 4 speed is the same length as a 904 , if you go to a 727 you need a shorter driveshaft.
Re: 4 speed to automatic conversion [Re: JohnRR] #1293056
08/28/12 06:23 PM
08/28/12 06:23 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
either trans...thank you for point out those differences...are there any other 904/727 differences at all?
Re: 4 speed to automatic conversion [Re: mshred] #1293057
08/29/12 09:19 AM
08/29/12 09:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
904 is lighter and has smaller internal parts , you'll need to spend $$$ to build either for nitrous, more on the 904.
Re: 4 speed to automatic conversion [Re: JohnRR] #1293058
08/29/12 07:26 PM
08/29/12 07:26 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks for the info. Is there anything else that I am missing about the swap???
Re: 4 speed to automatic conversion [Re: mshred] #1293059
08/30/12 11:46 AM
08/30/12 11:46 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
For a 727 you will be able to reuse your 30 spline slip yoke but for a 904 you will need a 26 spline slip yoke.
Re: 4 speed to automatic conversion [Re: 446acuda] #1293060
08/30/12 06:10 PM
08/30/12 06:10 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
I ran a 904 low gear trans in my 65 barracuda and it was the whip!
I think I bought it from Mazzalini racing.
I think that is how it is spelt?
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 4 speed to automatic conversion [Re: BB65Barracuda] #1293061
08/30/12 08:09 PM
08/30/12 08:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
ATF cooler, lines, shifter, wiring a Neutral safety switch, and doing something with the clutch pedal. Ballistic blanket probably. Figuring out the converter stall you need.
