Re: 4 speed to automatic conversion
[Re: JohnRR]
#1293056
08/28/12 06:23 PM
08/28/12 06:23 PM
Posts: 3,414 Toronto
mshred
Toronto
Which trans ? A body 4 speed is the same length as a 904 , if you go to a 727 you need a shorter driveshaft.
either trans...thank you for point out those differences...are there any other 904/727 differences at all?
[Re: mshred]
#1293057
08/29/12 09:19 AM
08/29/12 09:19 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
904 is lighter and has smaller internal parts , you'll need to spend $$$ to build either for nitrous, more on the 904.
[Re: JohnRR]
#1293058
08/29/12 07:26 PM
08/29/12 07:26 PM
mshred
Toronto
Thanks for the info. Is there anything else that I am missing about the swap???
[Re: 446acuda]
#1293060
08/30/12 06:10 PM
08/30/12 06:10 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I ran a 904 low gear trans in my 65 barracuda and it was the whip! I think I bought it from Mazzalini racing. I think that is how it is spelt?
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
