dome lamp wiring on 67 coronet #1292755
08/28/12 02:16 PM
08/28/12 02:16 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Can anyone tell me where the dome lamp plug connects to, i've been under the dash but cant find a connector for it.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: dome lamp wiring on 67 coronet [Re: deaks] #1292756
08/28/12 02:55 PM
08/28/12 02:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I am not 100% sure on a 67 but it should be in the same area , BEHIND the drivers side kick panel , where the tail light harness connects , it should be its own separate connector .
Re: dome lamp wiring on 67 coronet [Re: JohnRR] #1292757
08/28/12 03:06 PM
08/28/12 03:06 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I had a look behind there but couldn't see anything but maybe i didn't look hard enough.
Thanks Mick
best 60ft 1.36
Re: dome lamp wiring on 67 coronet [Re: deaks] #1292758
08/28/12 03:11 PM
08/28/12 03:11 PM
JohnRR Offline
JohnRR  Offline
It may connect to the tail light harness ? I'm going off memory and how a 68 and newer is . I do know it would be in that area because that is where the pigtail comes out .
Re: dome lamp wiring on 67 coronet [Re: deaks] #1292759
08/28/12 03:18 PM
08/28/12 03:18 PM
Glendale AZ
jimmyc340 Offline
jimmyc340  Offline
Glendale AZ
I believe its next to the drivers seat in the harness that goes back to the tail lights . You will probably have to pull the sill plate and carpet back but im pretty sure thats where it is. Its the orange and yellow wires
Re: dome lamp wiring on 67 coronet [Re: jimmyc340] #1292760
08/28/12 04:45 PM
08/28/12 04:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The wires are usually pink and yellow.
Re: dome lamp wiring on 67 coronet [Re: John_Kunkel] #1292761
08/28/12 06:17 PM
08/28/12 06:17 PM
JohnRR Offline
JohnRR  Offline
orange is the dim-able dash light circuit.
Re: dome lamp wiring on 67 coronet [Re: John_Kunkel] #1292762
08/28/12 06:19 PM
08/28/12 06:19 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Thanks everyone, i just need to look a bit harder.
Mick
best 60ft 1.36
Re: dome lamp wiring on 67 coronet [Re: deaks] #1292763
08/28/12 07:02 PM
08/28/12 07:02 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Mick, it's behind the drivers side kick panel on my Road Runner.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: dome lamp wiring on 67 coronet [Re: Mick70RR] #1292764
08/28/12 08:51 PM
08/28/12 08:51 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
The wiring goes from the driver's side kick panel up through the front window left c-pillar
Re: dome lamp wiring on 67 coronet [Re: rapom] #1292765
08/29/12 06:31 PM
08/29/12 06:31 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
The plug i thought was, from the dome light, turned out to be the one in the lighting loom and the one from the dome light was missing, anyway i managed to find a plug that matched from an old wiring loom and soldered it on.
Thanks Mick
best 60ft 1.36
