Re: 65 Formula S
[Re: Southern Wolf]
#1292385
08/27/12 08:57 PM
08/27/12 08:57 PM
RapidRobert
On a manual steering car I think they had a 16:1 manual steering box. Easy check is it'd be a little over 3 turns lock to lock whereas the std 24:1 is a little over 5 turns.
Re: 65 Formula S
[Re: Southern Wolf]
#1292386
08/27/12 09:02 PM
08/27/12 09:02 PM
from http://www.earlycuda.org/tech/tag.htmQuote:
Want to know if it's a Formula S? On the fender tag of a 65 Barracuda, look for the 'ABC'.... under the AB will be a '31' for the 273 4bbl 235hp engine. Under the C will be a '2' for the formula "S" package. The car should also have a tach in the dash....
Re: 65 Formula S
[Re: RapidRobert]
#1292387
08/27/12 11:58 PM
08/27/12 11:58 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Fast ratio manual was an option, not standard.
Re: 65 Formula S
[Re: Jim_Lusk]
#1292388
08/28/12 08:07 AM
08/28/12 08:07 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Fender tag only, but I don't know the code. Only the Formula S got the factory tach in 1965.
My '65 Valiant (bought new by me) had factory tach, F.R.M.S., manual discs, blue streaks, etc.
Rick
