Would you use this chipped brake drum? #1292157
08/27/12 01:00 AM
08/27/12 01:00 AM
Khemi, Stygia
Mebsuta Offline OP
Mebsuta  Offline OP
Khemi, Stygia
Would you use this chipped brake drum? That is 11 x 2-1/2 rear on 68 Plymouth RR. I have been trying to chase down a mysterious vibration and wonder if that could be the source.
The only new replacement drums in 11 x 2-1/2 that I can find are the finned ones (example Bendix PDR0365). Will those fit and work with the existing backing plates?
Everyone's catalog shows 68 RR with 10 inch rear, but no junior they had 11. Well at least one of them did; mine.
68 Roadrunner. 383 4-spd. Beat up.
Re: Would you use this chipped brake drum? [Re: Mebsuta] #1292158
08/27/12 01:13 AM
08/27/12 01:13 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yours isn't alone... Junior & his computer don't know half of what they think they do... I doubt thats your vibration & I've seen plenty of drums with similar damage run without issue for years, but if tracking a vibration I could see wanting to replace the drum just to eliminate it... But again I doubt it's the cause... Know anyone who has a drum you could borrow to test... Have you checked driveline angle?
Re: Would you use this chipped brake drum? [Re: 1_WILD_RT] #1292159
08/27/12 05:13 AM
08/27/12 05:13 AM
Khemi, Stygia
Mebsuta Offline OP
Mebsuta  Offline OP
Khemi, Stygia
Thanks. I will study the driveline angle.
Re: Would you use this chipped brake drum? [Re: Mebsuta] #1292160
08/27/12 07:58 AM
08/27/12 07:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes I agree with 1wildrt and very seriously doubt that is your vibration. I have used drums like that with no problem.
Re: Would you use this chipped brake drum? [Re: 1_WILD_RT] #1292161
08/27/12 08:49 PM
08/27/12 08:49 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Mill it square and do the same 180 degress across from it.
Re: Would you use this chipped brake drum? [Re: Mebsuta] #1292162
08/28/12 07:54 AM
08/28/12 07:54 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
W/O the disc option, rear drums were 11X2.5". With discs, rears were 10x2.5", unless your car had the Dana axle.
The finned drums bolt on and are a nice upgrade.
Rick
