Engine runs 15F cooler after oilchange (10w40 to 5w30) #1291832
08/26/12 07:30 PM
08/26/12 07:30 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
I changed the oil this week in my daily heap, the '73 Dart. I went from a regular dino 10w40 (with some ATF mixed in over time) to a synth. blend 5w30. Both oils were rated API SL.
Decided that even in the summer, the oilpressure was good enough to warrant a thinner oil in the engine.
First thing I noticed the oil pressure was pretty much the same as before; Oil pressure is 60-65psi cold idling and cruisin, and between 35-40 psi hot idling in Drive.
Most interesting however was the watertemperature.
Normally the engine runs at 160-170F, but now since the oil change, the temp hardly gets over 150F anymore in and around town.
Only on the highway the temp climbs back to 170, but that's because the radiator is pretty scaled up inside. (There is a 160F thermostat in the system.)
Does the newer oil take up engine heat that much better so it runs 15F cooler, or does the engine feel that much less friction and drag of the previous oil?
Or both?
I haven't got a tach in the car so I can't say for sure the engine runs faster now. But during cold morning starts, I does 'feel' (while driving off), as if the engine is already 'warm' and the oil is thin. It accelerates a bit smoother.
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: BigBlockMopar] #1291833
08/26/12 09:47 PM
08/26/12 09:47 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i have always heard the opposite of what you found. sounds interesting enough to give it a try though
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: BigBlockMopar] #1291834
08/26/12 11:52 PM
08/26/12 11:52 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: jcc] #1291835
08/26/12 11:57 PM
08/26/12 11:57 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
i have been taught to keep the engine 180 ..
you may run better ..
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: sogtx] #1291836
08/27/12 02:00 AM
08/27/12 02:00 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Some yes but not all............Jason Pettis used to set up Dougs motors to run real cold as in pushed to the line, fired up, burn out and 6-second et`s cold. Older carb equipted cars definately ran better warmed up especially if they were rich and todays car can literally be jumped in and thrashed.........see it everyday w/some people but I warm EVERYTHING up I own.........new or not.
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: Thumperdart] #1291837
08/27/12 10:29 AM
08/27/12 10:29 AM
The Netherlands
The Netherlands
I agree I would like to see temps a bit higher again near the 170F range. Especially when outside temps start to drop aswell. So I will install a 180 thermostat again somewhere soon.
For the moment I'm happy with the cooler temp as the motor has a rusted thin coreplug at the rear. With lower temps the coolingsystem builds a little less pressure and along with the 7 lbs rad.cap it will hopefully save this plug a little longer till I'm ready for my planned overdrive tranmission swap.
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: Thumperdart] #1291838
08/27/12 12:36 PM
08/27/12 12:36 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I guess i just figured that the OP's car was a street car .
I guess theres no doubt you make more power with a cold engine .. When drag racing..
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: sogtx] #1291839
08/27/12 12:45 PM
08/27/12 12:45 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Since I went to aluminum heads on my Dart and truck, I have to be at 180 when I leave the line. 160 or lower and it will lose a tenth. The dyno confirmed that on the truck engine as well. It was down almost 15 horsepower at 160 degrees compared to 180. Both pulls were with the oil temp at 160.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: BigBlockMopar] #1291840
08/27/12 01:11 PM
08/27/12 01:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think with the heavier oil you were working
the engine harder... driving the oil pump and the added
force on all the bearing with heavy oil...you have to
press the pedal a touch harder which is fuel which is
temp.... but I wouldnt have guessed 15*...I picked
up a bit when I changed to syn oil.... JMO
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: MR_P_BODY] #1291841
08/27/12 02:00 PM
08/27/12 02:00 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
From what I have read a semi synthetic is mostly dino oil, there is not set amount of synthetic it has to have to be called a semi ???
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: JohnRR] #1291842
08/27/12 02:06 PM
08/27/12 02:06 PM
dogdays Offline
dogdays  Offline
What probably happened is this: Your original setup pumping a higher viscosity oil needed less oil to the bearings because it wouldn't flow out of the bearings as fast; this caused your oil pump pressure relief valve to be operating most of the time, dumping oil back into the pan. Lowering the viscosity meant more oil could flow out of the bearings, less or no oil came out of the pressure relief.
Oil coming out of the pump is warmer than the oil going in, so bypassing some of that warmer oil into the pan raised the temperature. Stopping the bypass flow eliminated that source of heat.
R.
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: dogdays] #1291843
08/27/12 06:00 PM
08/27/12 06:00 PM
The Netherlands
The Netherlands
Sounds plausible.
JohnRR,
The oil is a Kendall GT-1 '5w30' (API SL). The can said 'Synthetic Blend'.
It is my believe all the base-oils are the 'dino'-stuff, but it's the type of additives that define if it's a synthetic or 'regular' oil.
Re: Engine runs 15F cooler after oilchange (10w40 to 5w30) [Re: BigBlockMopar] #1291844
08/28/12 12:31 PM
08/28/12 12:31 PM
dogdays Offline
dogdays  Offline
That's not correct. In the oil world, base stocks are defined by their "Group number". Petroleum oils start out with Group II or III, while synthetics start out with either Group IV, polyalphaolefins, or Group V, which is composed of many different types of base stock that had no place elsewhere.
"Oil Base Stocks
www.zddplus.com/TechBrief10%20-%20Oil%20Base%20Stocks.pdf · PDF file"
Synthetics have a flatter viscosity curve per temperature, so they need less Viscosity Index improver or none at all. VI improvers have a tendency to shear and lower the viscosity at higher oil temps, which in the '80s led to engine failures.
R.
