Fluidamper install on my 383 #1291112
08/25/12 01:00 PM
08/25/12 01:00 PM
Kentucky
E
ewolfe Offline OP
ewolfe  Offline OP
E
Kentucky
I can't seem to get the damper to seat enough to get the factory bolt and washer back in the crank to secure the damper.
I have installed and removed it on my 383 three times thinking maybe the key on the crank wasn't sliding into the damper, but I know it is. I chamfered both the key and the opening in the damper to allow access.
Is this normal? Do I need a longer bolt? Obviously my pullies now don't line up as the balancer is much thicker than the stock one it replaced.
Can you offer any suggestions? I know it sounds dumb, but it wont work for me.
Re: Fluidamper install on my 383 [Re: ewolfe] #1291113
08/25/12 01:10 PM
08/25/12 01:10 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Fluid dampers are known for being a tight fit on the crank and frequently need to have the hole enlarged a small amount. You can do this with some fine sandpaper and elbow grease.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Fluidamper install on my 383 [Re: HemiRick] #1291114
08/25/12 01:17 PM
08/25/12 01:17 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
does fluidamper make a thinner one like the ATI.i took the one off my race car and put it on a street motor and had to space everything way out,but the one i put on my other car was thinner and everything lines up perfect.i did have to hone them out a SLIGHT bit.
Re: Fluidamper install on my 383 [Re: HemiRick] #1291115
08/25/12 01:23 PM
08/25/12 01:23 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
One of these helps.
Mine is home made out of a piece of about 8" 3/4" fine threaded rod some washers and 3 nuts!
http://www.summitracing.com/parts/SUM-G1023/?rtype=10
Re: Fluidamper install on my 383 [Re: bonefish] #1291116
08/25/12 01:25 PM
08/25/12 01:25 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
IIRC I had to use a small block balancer bolt on mine. It's been years since I first fit it up though.
You may try to "warm" up the balancer, nothing over 180* IMO but I'd check their site first before hand.
Re: Fluidamper install on my 383 [Re: roadhazard] #1291117
08/25/12 01:35 PM
08/25/12 01:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes small block balance bolt is longer so that would work tell help start or go to a nut and bolt place and buy a longer 3/4" fine bolt and some washers to pull it in but you will probably still have to hone it / sand it a bit!
Re: Fluidamper install on my 383 [Re: Dodgem] #1291118
08/25/12 02:00 PM
08/25/12 02:00 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Do it right and get your machine shop to hone it to the correct size. Tim
Re: Fluidamper install on my 383 [Re: Dodgem] #1291119
08/25/12 02:12 PM
08/25/12 02:12 PM
Kentucky
E
ewolfe Offline OP
ewolfe  Offline OP
E
Kentucky
Ok, so it is normal for the short factory bolt not to fit once you've installed the balancer? After I've installed and removed it three times with my installer bolt setup, each time the factory bolt wont even touch the threads of the crank. I'll try a small block bolt and see if that reaches (remember, I'm talking about the bolt not being able to thread in once I've installed the balancer with an install kit)
Thanks, this was starting to worry me after spending the cash for the expensive Fluidamper.
Re: Fluidamper install on my 383 [Re: ewolfe] #1291120
08/25/12 02:42 PM
08/25/12 02:42 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Did it come with instructions ???
Most, if not all, AFTERMARKET balancers are required to be honed to size, they are made like that because not every crank snout is the same size and it needs to be HONED, not sanded by hand. you need a micrometer , measure YOUR crank snout , then have the balancer honed to size.
Re: Fluidamper install on my 383 [Re: ewolfe] #1291121
08/25/12 07:11 PM
08/25/12 07:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
regular bolt fits when it is all the way on the crank snot will be maybe .125 back of the outer part of the balancer that the big washer would butt up against!
Re: Fluidamper install on my 383 [Re: Dodgem] #1291122
08/25/12 10:37 PM
08/25/12 10:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used a brake cylinder hone on mine and now it fits perfect
Gus
64 Plymouth Savoy
Dana 60
Re: Fluidamper install on my 383 [Re: Dodgem] #1291123
08/26/12 03:10 PM
08/26/12 03:10 PM
Kentucky
E
ewolfe Offline OP
ewolfe  Offline OP
E
Kentucky
Thanks everyone. I'll pull it back off and hone it to fit.
I appreciate the info.
Re: Fluidamper install on my 383 [Re: ewolfe] #1291124
08/26/12 03:24 PM
08/26/12 03:24 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
While it is off measure the crank to the timing gear and you will know when it is on all the way.I have a BB damper and had to put it in a pan ov very hot water not on the stove and let it sit for 2/3 minutes then install it with a little anti seize.
