STUSKA ENGINE DYNOMOMETERS??? #1291079
08/25/12 11:58 AM
08/25/12 11:58 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Anyone here..besides Randy Johnson(Dartin)ever had an engine on one?...what was your opinion of it,as far as accuracy goes? I'm just curious! Thanks in advance! Randy
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291080
08/25/12 01:51 PM
08/25/12 01:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have had motors on the local Studka as well as on several different DTS and a Superfow, there all measuring devices Make sure the dyno operator and the dyno are current on the mandatory software upgrades and are willing to calibrate the dyno for your motor, see if they use a flywheel or not on thiers The local one didn't use a flywheel until we did one of my motors on thier dyno with a 30 lb. flywheel on it, you have to add the flywheel weight into the software tables The flywheel helps the motor to not accelerate rapidily when the dyno operator opens the throttle quickly, it wll not control the acceleration as quickly as it will with the flywheel on, it will rev way past the preset bottom RPM start limits and it takes a short while for the Studka dynos to pull the motor back below the starting RPM. The DTS do a lot better job of controlling this I try to use the flywheel that will be on the motor so why not duplicate what it will be in the car Is this your first time dyno tetsing a motor? If so let us know what you think when done My pucker factors goes to the moon every time they start a pull Even after hundreds of pulls There are two methods to do the dyno test pulls, manually and automated, I like the automated They can set the acceleration rate also, from 100 RPM per second to 1000 RPM per second, I think these numbers are accurate on the Studka software settings I think the industry standard is either 300 RPM per second or 600 RPM per second Each pulls takes longer at 300 per versus 600 per Have them do two pulls with no changes other than using 300 per and 600 per second recording rate and look at both sheets to see what differences there are and then decide which rate you want to use
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Cab_Burge] #1291081
08/25/12 02:13 PM
08/25/12 02:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The dyno in question uses no flywheel... it has its
own starter... he does use the auto mode for the
acceleration rate on the pulls... I'm sure I seen
600 as the rate when I was on it
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: MR_P_BODY] #1291082
08/25/12 02:39 PM
08/25/12 02:39 PM
All of the dyno I've used have thier own starters on the dyno driveshafts or internally, none of them used the starter to operate the flywheel ring gear to start the motors I've used both the 300 per and the 600 per, not sure which one we ended up using OP, make sure that the dyno sheets show that the HP and torque are equal at 5250 RPM If not something is wrong with that dyno or the software set up on it I just remember another thing about the recording rate, it can capture and record information from 50 RPM increments up to whatever the upper levels are. I like 100 RPM increments, some people like 50 RPM increments I've had both, as I said I like and use the 100 RPM setting One last thing is the start and finish RPM, I like to start off the first pulls with 2500 or 3000 RPM for the lower limits and 5000 or 5500 RPM for the upper limit. If the motor is new it will take anywheres from 5 to 12 full pulls to seat the rings and quit gaining power on each pull Once it levels off(repeats within 1% ) we will look at the results and then decide to change the RPM settings, if it is a street motor with a 3000 RPM converter we may leave the lower RPM limit at 3000 RPM and raise the upper to 6000 RPM if the motor shows that it is still gaining HP at the old upper RPM limit. I try to use 500 RPM above the peak HP settings for the upper RPM stop settings, I have seen jetting make the peak HP setting RPM increase, go up from 5900 RPM to 6300 RPM I've also seen almost no change in power and torque from 6500 RPM to 7200 RPM on a race motor with high compression and a big cam I like to raise the upper RPM until I see a difenint(SP?) falling off of the motors peak HP RPM. Good luck, have fun
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Cab_Burge] #1291083
08/25/12 02:56 PM
08/25/12 02:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The dyno does have a inertia wheel on it and all
they hook to the engine is the drive shaft on the dyno
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Cab_Burge] #1291084
08/25/12 04:10 PM
08/25/12 04:10 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Cab! Waiting on a few engine pieces to get er' back together again! Waiting on the delivery of a new timing chain cover..and I still have to go to Trend and order up some heavy duty pushrods!
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291085
08/25/12 06:10 PM
08/25/12 06:10 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Mine was done on an antique Stuska with none of those fancy computer controls. Brake in one hand and throttle in the other. He has relented and added data acquisition since mine was done.
We picked our RPM points, applied brake until it held each point with the throttle firewalled and waited a few seconds until everything stabilized to take the reading. (BIG 12" gauage). His dyno is track proven to be about 10% stingy.
Kevin
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291086
08/25/12 07:13 PM
08/25/12 07:13 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes. I like it and will continue to do back to it/him. It is as much the operator as the equipment. The owner/operator I use is small time, and a Pontiac guy. He sells nothing but dyno time.
I dont know if it is accurate, but it was very, very consistent. My engine sat on the dyno for a week and I made a lot of changes (carbs, intakes, intake modifications, spacers, and lash) and a lot of pulls. About 1/3 of the pulls were duplicate runs just so I could convince myself that the results were repeatable, adding validity to the results observed for each change.
I run regularly with 3 other guys that have dyno results for their engines from nationally recognized shops. I have their dyno sheets in my possession, and their car weights. Based on their data, they should all be faster than me. None of them are.
But don't lose perspective on what a dyno is; a tool. If you are not going to use it as a tool, why spend the money, as the numbers mean little otherwise. The only numbers that have meaning you'll find on your time slip.
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: BSB67] #1291087
08/26/12 03:06 PM
08/26/12 03:06 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
That's what John Lingenfelter had when I worked for him, he always liked them.
Joey
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: jake4cars] #1291088
08/26/12 04:18 PM
08/26/12 04:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would rather have it close or even a bit stingy
on the numbers than some of the dyno numbers I have
heard on here and knowing what the car ran... I dont
care about some big BS number and the car will never
see it on the track
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: MR_P_BODY] #1291089
08/26/12 09:05 PM
08/26/12 09:05 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Final numbers are nice to brag about but most people miss the point of using a dyno to tune a motor. It's the change you see from start to finish, finding out what the motor wants and what doesn't work. As long as the dyno is repeatable it doesn't matter which brand you use. Dave
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: quickd100] #1291090
08/26/12 11:57 PM
08/26/12 11:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The Dyno is a tool, use it wisely.
The ultimate gauge of Hp is what it runs when installed in the car and run at the track. An engine could make 900HP on the dyno but a run at the track could show it only making 600 ... which do you believe ?
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: quickd100] #1291091
08/27/12 12:15 AM
08/27/12 12:15 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I hired a shop that uses Stuska dyno to show this engine was ready to go for the buyer. Since it was sold pending the dyno runs, I was a little nervous when it hit the upper rpm range. The guys there wanted to run it a little higher and I said no. It is going into a show car!
This dyno was manually loading, and the owner said it is conservative compared to some others.
http://www.youtube.com/watch?v=B__c9JhjJlo&feature=channel&list=UL
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Hemi Allstate] #1291092
08/27/12 12:32 AM
08/27/12 12:32 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
As Dave and John said,it is a great tool for gauging the effects of changes made. Don't get too hung up on trying to compare your numbers to someone else's
I own a Superflow engine dyno but before I bought it I looked at all of them.
The Stuska numbers will be different than the same setup on a Superflow. The modern Stuska setup is very repeatable and user friendly because it does not force the engine to accelerate at a determined rate controlled by the computer software . Instead,it accelerates at a rate dependant on the power of the engine,and the software converts the data into what it "should"be at the desired rate. A lot of manipulation goes on to make it seem very repeatable.
This is not a dig at anybody else's setup,just my take on it. I prefer to use a setup that controls the acceleration rate by a servo controller and does less manipulation
Any dyno is only as good as the guy running it and how accurately and often he calibrated it.
Keith
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Dunnuck Racing] #1291093
08/27/12 06:07 AM
08/27/12 06:07 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Randy,
A chassis dyno is usually much cheaper to test on will give good tuning results.
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291094
08/27/12 10:10 AM
08/27/12 10:10 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I own a SF-Powermark dyno and I think the most important numbers are the average HP and torque over the sweep area. Having a higher average will be faster than having a higher peak power. Sweep rate shouldn’t matter if the software compensation is correct.
Joe
FYI 1% is way too much variation, run to run, for a good dyno.
Without Data, you’re just another guy with an opinion.
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291095
08/27/12 10:22 AM
08/27/12 10:22 AM
detroit area
moderncylinder Offline
detroit area
how much is it for a day on st clair's dyno?
400? 500? 600?
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: moderncylinder] #1291096
08/27/12 10:47 AM
08/27/12 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
400? 500? 600?
$500
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: viperblue72] #1291097
08/27/12 01:03 PM
08/27/12 01:03 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Chad Lee,I want my freshly built motor broken-in BEFORE installing it back in my GTX. My main reason to dyno it is to make sure there are NO PROBLEMS with oil pressure issues..oil leaks,etc.,etc! How much power it makes is SECONDARY to me. I'm sure with Jeff's head work...and nice ROUND cylinders,she'll do just fine! Having the person that put the bottom end together,pulling the levers on the dyno,is another good reason! I call it "insurance"! From the responses I'm getting,sounds like the Stuska is slanted a bit toward the stingy side...which to me,is preferable. I had the engine tune pretty well dialed-in,before Jeff did the heads. I'm sure it'll be a whole new ball game now!...just ANOTHER GOOD REASON to "Dyno-Tune" it,before installation! In my opinion..$500.00 well spent,for sure!
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291098
08/27/12 01:10 PM
08/27/12 01:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... From the responses I'm getting,sounds like the Stuska is slanted a bit toward the stingy side...which to me,is preferable.
Not from my experience, since the Stuska / DePac system I tested on seemed to kick out results about 10% higher than the SuperFlow I tested on a few years later.
However, this just reinforces the belief that you should really never try to compare the results from two different dynos unless you can test the same engine on both to verify consistency.
As others have said before, a dyno is just another tool and should be used accordingly.
