B Body Sub Frame Connectors #1289663
08/22/12 04:25 PM
08/22/12 04:25 PM
Chicago, IL
sixpkrt Offline OP
sixpkrt  Offline OP
Chicago, IL
I'm in need of recommendations of which sub frame connectors to use for my 70 Coronet.
I've been considering US Car Tool Part # USCT1M1101, since it looks like I wouldn't have to cut the floor, but I'm unsure how rigid these are. (I'm not racing my Coronet, but I do stomp on it occassionally).
The other question is to go with weld in or bolt on sub frames. Like mentioned above, I really don't want to cut the floor, so subs that run below the floor would be best.
Any feed back on best route to go would be appreciated.
1970 Dodge Coronet R/T
Re: B Body Sub Frame Connectors [Re: sixpkrt] #1289664
08/22/12 04:57 PM
08/22/12 04:57 PM
moparAL Offline
moparAL  Offline
Check out Auto Rust Technicians www.autorust.com sub-fame connectors. Reasonably priced $120.00, Mopar guys, built in hole for emergency brake cables, and they hang high (from the pictures).
Re: B Body Sub Frame Connectors [Re: moparAL] #1289665
08/22/12 05:32 PM
08/22/12 05:32 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Those Autorust connectors look reasonable. I run the Hotchkis connectors. By far the nicest on the market with no mods needed to the floor. They tie in from the front and use rear spring mount as a tie in point.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: B Body Sub Frame Connectors [Re: Viol8r] #1289666
08/22/12 05:46 PM
08/22/12 05:46 PM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
Second the Hotchkis. Their design eliminates the need for torque boxes because they attach to the spring hangers and attach at the front frame rail. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: B Body Sub Frame Connectors [Re: HUSTLESTUFF] #1289667
08/22/12 09:50 PM
08/22/12 09:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Rick Ehrenberg has made it clear that he prefers The thickest, boxed type connectors that you can use. The type that are contour cut to match the floorpan look clean, but they are only as strong as their thinnest section.
I made my own for less than $50. I did cut the tops to clear the floor, but REboxed where I cut to maintain stength.
Re: B Body Sub Frame Connectors [Re: Kern Dog] #1289668
08/22/12 11:08 PM
08/22/12 11:08 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I think a more precise statement might be:
"Reboxed where I cut to REGAIN SOME of the lost strength due to cutting."
Re: B Body Sub Frame Connectors [Re: jcc] #1289669
08/23/12 11:36 PM
08/23/12 11:36 PM
Chicago, IL
sixpkrt Offline OP
sixpkrt  Offline OP
Chicago, IL
Thanks for the helpful info. Autorust had the connectors and torque boxes available as a kit. Seemed like the best deal. They should be here by next Wednesday.
Re: B Body Sub Frame Connectors [Re: sixpkrt] #1289670
08/24/12 02:32 AM
08/24/12 02:32 AM
moparAL Offline
moparAL  Offline
sixpkrt,
You are welcome. I am going to do exactly what you did, Autorust subframes and Autorust torque boxes kit. Good luck with your project.
Re: B Body Sub Frame Connectors [Re: sixpkrt] #1289671
08/24/12 08:32 AM
08/24/12 08:32 AM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
Autorust stuff is fine. The torque boxes rock.
Got old MP sfc's and autorust boxes on Black Betty. Didn't have many choices 10 years ago.
Have USCartool sfc's and autorust boxes on Sinnamon. I was gonna use 2x3 steel and cut the floor but got talked out of it. Make no mistake the USCartool stuff is strong as all heck.
UScartools are definitely more work / welding but the end result looks good. The autorust and MP's are basic welded on square tubing. Functional. Maybe not the prettiest.
Anything is better than doing nothing at all.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: B Body Sub Frame Connectors [Re: BrianShaughnessy] #1289672
08/24/12 01:10 PM
08/24/12 01:10 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I made my own this past winter for my 71 runner - get 1"x3" - clears the floor without cutting, cost was cheap (i think it was $30 for a 10' piece)
Re: B Body Sub Frame Connectors [Re: dangina] #1289673
10/20/12 12:13 AM
10/20/12 12:13 AM
NC
ChrisUSCT Offline
ChrisUSCT  Offline
NC
Here are the US Car Tool Connectors Welded on!
US CAR TOOL Chris Lewis chris@uscartool.com (919)855-8200
Re: B Body Sub Frame Connectors [Re: ChrisUSCT] #1289674
10/20/12 11:52 AM
10/20/12 11:52 AM
dangina Offline
dangina  Offline
Looks good!
Re: B Body Sub Frame Connectors [Re: Kern Dog] #1289675
10/20/12 07:28 PM
10/20/12 07:28 PM
Denver
E
Explodo Offline
Explodo  Offline
E
Denver
While it's true that taller ones will be stronger, my US Car Tool connectors are over 2" tall at the SHORTEST point.
'67 440 Satellite
Re: B Body Sub Frame Connectors [Re: sixpkrt] #1289676
10/20/12 10:20 PM
10/20/12 10:20 PM
AndyF Offline
AndyF  Offline
I covered the topic in my B-body book. I included pictures of various parts from different vendors.
Re: B Body Sub Frame Connectors [Re: AndyF] #1289677
10/21/12 02:20 PM
10/21/12 02:20 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Here is a photo of the ones on my roadrunner.
Re: B Body Sub Frame Connectors [Re: MidPenMopar] #1289678
10/21/12 02:21 PM
10/21/12 02:21 PM
MidPenMopar Offline
MidPenMopar  Offline
one more shot
Re: B Body Sub Frame Connectors [Re: jcc] #1289679
10/21/12 02:29 PM
10/21/12 02:29 PM
Kirkland, Washington
Pacnorthcuda Offline
Re: B Body Sub Frame Connectors [Re: Pacnorthcuda] #1289680
10/21/12 08:06 PM
10/21/12 08:06 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
2x3" rectangle tube, .100 wall. Protrudes through the floor only in the back seat passenger feet area. It sticks up around 1" or so, trim the insulation out from the carpet over top of them, then throw your rug and floor mats in and it's not even an issue. Under the front seats and front passenger/driver feet area it stays under the floor. Cut a slot into the front of the rear sub-frame and the 2x3 tube fits right inside.
