need master cyl for low vac engine #1289596
08/22/12 01:09 PM
08/22/12 01:09 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Is there an aluminum master I can use to help out with power brake booster that does not see much vacuum? It on a 71 e body.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: need master cyl for low vac engine [Re: EV2CUDA] #1289597
08/22/12 01:12 PM
08/22/12 01:12 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i dont think so
Re: need master cyl for low vac engine [Re: 05dakota] #1289598
08/22/12 01:17 PM
08/22/12 01:17 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Get an electric vacuum pump.
Kevin
Re: need master cyl for low vac engine [Re: EV2CUDA] #1289599
08/22/12 01:53 PM
08/22/12 01:53 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Turn the in gear idle up that's all I did for 30 years. My 509 wanted 950, my 533 1050 my 597/620 ultra dye solid wanted 1150, my 703/713 roller wanted 1250 but alas my booster finaly pooped so just took it off and went manual! buy or make a vacuum reservoir? Buy a vacuum pump.
Oh and first make sure the check valve at the booster is working and don't pump the brakes
Re: need master cyl for low vac engine [Re: Dodgem] #1289600
08/22/12 02:09 PM
08/22/12 02:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: need master cyl for low vac engine [Re: Dodgem] #1289601
08/22/12 05:04 PM
08/22/12 05:04 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I have put on 2 stock napa units and both leaked after a while. Looking for an aluminum off of something newer. I will look into an electric vac pump too.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
