How bad is this broken casting on my 904? #1288644
08/20/12 04:25 PM
08/20/12 04:25 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
I saw this broken casting for the starter pin on my 904 a few months ago when I removed the transmission. I did not find the missing piece. Is this OK to use? Should I try to fix it?
The flywheel is fine.
Thanks.
Re: How bad is this broken casting on my 904? [Re: cudabitten] #1288645
08/20/12 04:27 PM
08/20/12 04:27 PM
Texas
ChristianCuda Offline
Texas
I would say its fine. Probably was someone torqued down the started and it wasn't properly seated in the hole.
Re: How bad is this broken casting on my 904? [Re: ChristianCuda] #1288646
08/20/12 04:42 PM
08/20/12 04:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just make sure it didn't crack the case
