power windows - insufficient power #1288035
08/19/12 10:17 PM
08/19/12 10:17 PM
Myrtle Beach, SC
DRED Offline OP
DRED  Offline OP
Myrtle Beach, SC
Have a 70 Challenger with factory power windows. Wiring harness looks OK. Switches have been rebuilt and terminals cleaned. All harness connectors have been cleaned.
Problem: The passenger front window motor doesn't have enough power to fully raise the window. When hot-wired, the motor works just fine. Neither the drivers master switch nor the switch on the passenger door allows the window to raise fully. When checked, the voltage is 11.2 at the connector to the motor when the switch is pressed to the up or down position. It's the same from either switch. The other windows work fine, although all move slower heading to the up position. They do close fully. I don't think it is the window track adjustment as it works ok when hot-wired. I have taken apart the terminal that the window switch plugs into and cleaned the "loops" of the terminals. Also, I compressed the metal "loops" in the terminal so it would mate well to the switch.
Not sure where to go from here. It seems there are not enough amps when going through the wiring harness to raise the windows. Any suggestions?
Re: power windows - insufficient power [Re: DRED] #1288036
08/19/12 10:45 PM
08/19/12 10:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: power windows - insufficient power [Re: DRED] #1288037
08/20/12 01:56 AM
08/20/12 01:56 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
How / where did you get the switches rebuilt?
The Relays as in the previous post work great!
Re: power windows - insufficient power [Re: 451Mopar] #1288038
08/20/12 09:09 AM
08/20/12 09:09 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
quote: When checked, the voltage is 11.2 at the connector to the motor when the switch is pressed to the up or down position.
is this with the motor connected?????? if not- then check it with it connected and report.
Re: power windows - insufficient power [Re: 71_deputy] #1288039
08/20/12 10:22 AM
08/20/12 10:22 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
But also realize the motor grounds through the second wire so rather than reading voltage to a known good ground read the voltage through the second wire.... They switch polarity to reverse these motors... So the ground path is through the single switch back to the master switch, through five separate connectiona on the ground side plus seven connections on the power side.. Add two switches per direction of power flow & it's easy to see why after 35 years they have issues...
Add the relays, it'll work better than it did when new...
Re: power windows - insufficient power [Re: 1_WILD_RT] #1288040
08/20/12 01:40 PM
08/20/12 01:40 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
if you check the voltage either way with the motor connected and it reads like 8-10 volts- there could be a problem with the motors wires where it goes from the doors to the frame- after yaers of opening/closing they can break inside the wcovering and will not allow all the current to flow to the motor.
john mac
Re: power windows - insufficient power [Re: DRED] #1288041
09/15/12 04:42 PM
09/15/12 04:42 PM
AZ.
696pack Offline
696pack  Offline
AZ.
OK, I have a 1966 Dodge Charger with slow factory power windows.
I have cleaned all of the old grease from the regulators with brake kleen and relubed them and it did no good.
I have read through this thread and the link posted of the other tread and I am completely confused.
Can someone give me the simplest, most cost effective fix for this, with readily available parts please?
Re: power windows - insufficient power [Re: 696pack] #1288042
09/16/12 03:06 PM
09/16/12 03:06 PM
AZ.
696pack Offline
696pack  Offline
AZ.
btt
Re: power windows - insufficient power [Re: DRED] #1288043
09/16/12 03:20 PM
09/16/12 03:20 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Dred,
There are hidden internal splices in the factory harness. Cleaning or replacing only the ends does not necessarily solve the problem. There can be heavy corrosion still hiding. There are some pictures at the bottom of my JS Restorations thread on page 2 at the bottom that shows before and after with those splices. Take a meter and check the impedance on the lines from the master switch socket to the ends for the passenger motors and see what you read.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: power windows - insufficient power [Re: Slotts] #1288044
09/17/12 01:52 AM
09/17/12 01:52 AM
AZ.
696pack Offline
696pack  Offline
AZ.
Bump for my question two posts up
