For some reason my battery is not charging. I put a new alternator on it and it still wont keep the battery charged. The battery is new. The car will sometimes stop running while driving. I can jump start it, and sometimes it will run for the rest of my trip, and other times it will stop running after only a mile or so. Sometimes it will run perfect and after i shut it down for a few minutes and then try to start it again, like when getting gas, it wont start and the battery is drained. what would cause my alternator to not charge the battery. I'm guessing I have a bad wire somewhere, but I"m not sure where to begin looking. Also have always had some issues with the dash lights working intermittently, but now seems worse and no turn signals. I'm assuming this is a bad ground. Could the same bad ground be causing both problems?
