how do u remove a hood pop up spring on a 71 challenger #1287150
08/17/12 09:59 PM
08/17/12 09:59 PM
W. Bloomfield, MI
71340vert Offline OP
W. Bloomfield, MI
never thought this would be hard to do until i had to try. not sure if there is some trick or just pry it out
Re: how do u remove a hood pop up spring on a 71 challenger [Re: 71340vert] #1287151
08/17/12 10:50 PM
08/17/12 10:50 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
If its the same as a B body I use a 7/16 1/4 drive socket on a long extension and pull the bolt out.
Re: how do u remove a hood pop up spring on a 71 challenger [Re: 71340vert] #1287152
08/18/12 01:32 AM
08/18/12 01:32 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Grab the spring & twist..It will step over the raised area & pop out from the metal tang...
Re: how do u remove a hood pop up spring on a 71 challenger [Re: 71340vert] #1287153
08/18/12 09:58 AM
08/18/12 09:58 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
with a flat bladed screwdriver lift up the bent over tang on the header panel holding the spring down.(it doesn't take much )
Then grab the spring twist and slide it out
