reuse bulkhead wiring block #1287130
08/17/12 07:54 PM
08/17/12 07:54 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Hope that's the right term. I'm rewiring my 62 Savoy and would like to reuse my old bulkhead wiring block. Are they reusable ? I can't get the wires out. I'm thinking there is a secret trick like sticking a small screw driver in somewhere, but I'm not having any luck.
Uploaded with ImageShack.us
Re: reuse bulkhead wiring block [Re: 62440] #1287131
08/17/12 08:02 PM
08/17/12 08:02 PM
get a mini eyeglass screwdriver & insert it in the little notch on one of the long sides of the rectangle on the front side & Carefully flatten the locking tang on the back side of the brass terminal. Keep trying and do not bend/force anything or lever the screwdriver too far to the side which would damage the bulkhead & when you have it depressed the right amt the wire/terminal will easily pull out of the back side
Re: reuse bulkhead wiring block [Re: RapidRobert] #1287132
08/17/12 08:23 PM
08/17/12 08:23 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Thanks Robert. That did the trick. Just took a bit more push than I expected.
