Cheetah shifter and Buchellon Kick down cable trouble *DELETED* #1286234
08/16/12 09:03 AM
08/16/12 09:03 AM
west palm beach, florida
modelmakerinc Offline OP
Sorry guys I was thinking I could delete the whole thread and repost when I had pictures. it only deleted my first post.
anyway I wasonly asking if anyone had run into the cheetah shifter and buchellon kick down brackets using the same mounting holes and causing interference
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Cheetah shifter and Buchellon Kick down cable trouble [Re: modelmakerinc] #1286235
08/16/12 08:51 PM
08/16/12 08:51 PM
Ohio
W
wedgg440 Offline
wedgg440  Offline
W
Ohio
Just refer to your instruction sheet under trans cable installation.It explains what to do to to make it work.You just have to enlarge the hole in their bracket to 1/2in. dia.Good luck!!
Re: Cheetah shifter and Buchellon Kick down cable trouble [Re: wedgg440] #1286236
08/16/12 08:57 PM
08/16/12 08:57 PM
yeah the instructions do cover basic install. But the bracket actually interferes with the cable itself. You can force the fit but I am going to do a simple mod to bracket for better fitment. I will post the pics soon. Thanks
Re: Cheetah shifter and Buchellon Kick down cable trouble [Re: modelmakerinc] #1286237
08/17/12 12:30 PM
08/17/12 12:30 PM
Indiana
P
Pentastar440 Online content
Pentastar440  Online Content
P
Indiana
I also have a Cheetah shifter, I also would like to use a Buchellon kickdown cable. Mine is on a '38 Plymouth with an a518 transmission. I thought that there could be a problem hooking up both cables at the same mounting location. It would be great to see some pictures of how you made this work.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Cheetah shifter and Buchellon Kick down cable trouble *DELETED* [Re: modelmakerinc] #1286238
08/17/12 01:05 PM
08/17/12 01:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Post deleted by modelmakerinc
Re: Cheetah shifter and Buchellon Kick down cable trouble [Re: Pentastar440] #1286239
08/17/12 01:53 PM
08/17/12 01:53 PM
Pentastar, It was really so simple that I figured pictures wouldnt be needed.
I'll explain: the brackets do use the same mounting boss, as was stated earlier in the post you must drill out the Buchellon bracket to 1/2" dia. hole. The other thing that must be done for an easy non binding fit is to just grind/ file a 1/2" radius into the buchellon bracket at the level of the cables metal sheath.
Here is the bracket unmodified you can see that the cables sheath will not let it aline square to the linkage
here is the simple fix 1/2" radius out of the side of the bracket
hope this helps. Henry
Re: Cheetah shifter and Buchellon Kick down cable trouble *DELETED* [Re: modelmakerinc] #1286240
08/17/12 08:25 PM
08/17/12 08:25 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Great job!
What's the point?
Earning every penny of that moderator paycheck.
DBAP
Re: Cheetah shifter and Buchellon Kick down cable trouble *DELETED* [Re: not_a_charger] #1286241
08/18/12 03:34 AM
08/18/12 03:34 AM
indiana
marks69 Offline
marks69  Offline
indiana
Buy Lokar and be done of it.
Re: Cheetah shifter and Buchellon Kick down cable trouble *DELETED* [Re: marks69] #1286242
08/18/12 08:30 AM
08/18/12 08:30 AM
the house on the left.
cogen80 Offline
cogen80  Offline
that sucks.. my lokar cable worked perfect together with the turbo action shifter.
Buchellon not think anyone would use a good shifter with their kickdown kit??
