big block water pump housing heater hose location #1285503
08/14/12 08:33 PM
08/14/12 08:33 PM
Idaho
boomerodell Offline OP
Idaho
What port on the wp housing is the pressure side and what one is the return? Thanks
Re: big block water pump housing heater hose location [Re: boomerodell] #1285504
08/14/12 09:52 PM
08/14/12 09:52 PM
hot coolant exits the block in the top 2 holes on each side so on the pass side on top of the pump where the coolant turns from the top block hole inward to the stat housing is the pressure nipple.
Re: big block water pump housing heater hose location [Re: RapidRobert] #1285505
11/01/12 01:33 AM
11/01/12 01:33 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
So which heater hose fitting is the pressure?? The one closest to the block??
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: big block water pump housing heater hose location [Re: Prodart440] #1285506
11/01/12 03:18 AM
11/01/12 03:18 AM
The top one (highest) The next question on the heater niples is which one is the inlet
Re: big block water pump housing heater hose location [Re: Cab_Burge] #1285507
11/01/12 11:14 PM
11/01/12 11:14 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...out of a 70 shop manual.
Re: big block water pump housing heater hose location [Re: thehemikid] #2961826
09/07/21 11:35 AM
09/07/21 11:35 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Which heater hose nipple is the 1/2" and which is the 5/8" on the '70 and up?
Re: big block water pump housing heater hose location [Re: 71charger] #2961829
09/07/21 11:57 AM
09/07/21 11:57 AM
an8sec70cuda Offline
The smaller 1/2" hose is the rearmost port on the water pump housing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: big block water pump housing heater hose location [Re: boomerodell] #2961850
09/07/21 12:58 PM
09/07/21 12:58 PM
AndyF Offline
AndyF  Offline
If you look at the water pump housing you can figure it out. There is a pressure side of the housing and a return side. The pressure side feeds the heater (and the radiator) while the return side pulls water in from the radiator as well as the return from the heater.
Re: big block water pump housing heater hose location [Re: AndyF] #2961868
09/07/21 01:36 PM
09/07/21 01:36 PM
A727Tflite Offline
A727Tflite  Offline
Look at the provided schematic - there are arrows showing direction.
Re: big block water pump housing heater hose location [Re: an8sec70cuda] #2962022
09/07/21 09:31 PM
09/07/21 09:31 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Thank you
Re: big block water pump housing heater hose location [Re: 71charger] #2962035
09/07/21 10:22 PM
09/07/21 10:22 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
How about a small block wp?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: big block water pump housing heater hose location [Re: BloFish] #2962304
09/08/21 07:50 PM
09/08/21 07:50 PM
Quote
the nipple next to the intake stat housing is the hot coolant outlet to the firewall heater inlet nipple. heater outlet nipple is to the water pump fitting. EDIT be sure to hook the 2 hoses to the 2 heater core nipples to the right ones
