Re: big block water pump housing heater hose location
[Re: boomerodell]
#1285504
08/14/12 09:52 PM
08/14/12 09:52 PM
RapidRobert
hot coolant exits the block in the top 2 holes on each side so on the pass side on top of the pump where the coolant turns from the top block hole inward to the stat housing is the pressure nipple.
[Re: RapidRobert]
#1285505
11/01/12 01:33 AM
11/01/12 01:33 AM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
So which heater hose fitting is the pressure?? The one closest to the block??
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: 71charger]
#2961829
09/07/21 11:57 AM
09/07/21 11:57 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
The smaller 1/2" hose is the rearmost port on the water pump housing.
[Re: boomerodell]
#2961850
09/07/21 12:58 PM
09/07/21 12:58 PM
Posts: 31,050 Oregon
AndyF
What port on the wp housing is the pressure side and what one is the return? Thanks If you look at the water pump housing you can figure it out. There is a pressure side of the housing and a return side. The pressure side feeds the heater (and the radiator) while the return side pulls water in from the radiator as well as the return from the heater.
[Re: an8sec70cuda]
#2962022
09/07/21 09:31 PM
09/07/21 09:31 PM
Posts: 2,015 Frederick, MD
71charger
Frederick, MD
The smaller 1/2" hose is the rearmost port on the water pump housing. Thank you
[Re: 71charger]
#2962035
09/07/21 10:22 PM
09/07/21 10:22 PM
Posts: 16,487 On the run…
BloFish
On the run…
How about a small block wp?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2962304
09/08/21 07:50 PM
09/08/21 07:50 PM
RapidRobert
How about a small block wp? the nipple next to the intake stat housing is the hot coolant outlet to the firewall heater inlet nipple. heater outlet nipple is to the water pump fitting. EDIT be sure to hook the 2 hoses to the 2 heater core nipples to the right ones
