Orange box doesn't provide spark while cranking? #1285342
08/14/12 04:15 PM
08/14/12 04:15 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
Hey everyone. I'm running a 383 with a typical electronic ignition setup. It's a factory single pickup distributor and an MP orange box. I am using a factory ballast resistor. No problems for years.
Recently though, the car started having some difficulties starting up. It would crank with no results, but sometimes when I let go of the key the engine would start up. I suspected it wasn't getting power while cranking, so I had a friend hold a multimeter on the coil. I am getting about 8 volts key on, and 12 volts while cranking. However, I am still having intermittent startup issues (doesn't do it every time, but acts up more so when hot). Is it possible the orange box can be getting power but not triggering the spark? Does a warm engine bay effect the box?
"Broke is temporary, cheap lasts forever"
Re: Orange box doesn't provide spark while cranking? [Re: 68Bullet] #1285343
08/14/12 04:18 PM
08/14/12 04:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Orange boxes are know to be junk. You'll be better off going back to a stock box. They actually work better.
Re: Orange box doesn't provide spark while cranking? [Re: stumpy] #1285344
08/14/12 05:24 PM
08/14/12 05:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If you have an older orange they work fine. I bought mine in 2002 and it is still working fine on my 63. It works good enough to run 10's without missing a beat.
But the box is not your problem. The ign switch bypasses the ballast while cranking and supplies the coil and orange ECU voltage while cranking. If I would suspect anything I would think the ign switch may be your problem. Did you check the voltage at the coil and ECU when it would not start or was it starting ok when you checked it ? Ron
Re: Orange box doesn't provide spark while cranking? [Re: 68Bullet] #1285345
08/14/12 05:27 PM
08/14/12 05:27 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Make sure the box has a good ground. Tighten or twist the bolts back and forth. I've had that type of problem and it was a ground issue. Also check the ballast resitor.
Re: Orange box doesn't provide spark while cranking? [Re: 383man] #1285346
08/14/12 06:03 PM
08/14/12 06:03 PM
IL
furious70 Offline
furious70  Offline
IL
I'm with Ron, no fire when cranking but tries to catch when you let off the key is usually a telltale sign of the ign switch.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Orange box doesn't provide spark while cranking? [Re: 383man] #1285347
08/14/12 06:24 PM
08/14/12 06:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
makes alot of sense
Re: Orange box doesn't provide spark while cranking? [Re: mikemee1331] #1285348
08/14/12 07:42 PM
08/14/12 07:42 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I also suspected the ign switch. That is why I had my friend use a multimeter to check voltage at the coil positive terminal while cranking. He read a full 12 volts at the coil while cranking, but no spark. That is why I suspect the orange box. However, it is sounding like it could also be the coil too.....
Re: Orange box doesn't provide spark while cranking? [Re: 68Bullet] #1285349
08/15/12 10:36 AM
08/15/12 10:36 AM
The Great White North
RAMM Offline
RAMM  Offline
Probably pick-up coil. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Orange box doesn't provide spark while cranking? [Re: RAMM] #1285350
08/15/12 11:17 AM
08/15/12 11:17 AM
My vote: pickup coil or ECU
Re: Orange box doesn't provide spark while cranking? [Re: 68Bullet] #1285351
08/15/12 11:24 AM
08/15/12 11:24 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That is the typical symptom of bad grounding. Run a ground wire from the ignition box to the engine block,and check the battery cables for good connections.
