Orange box doesn't provide spark while cranking?
#1285342
08/14/12 04:15 PM
08/14/12 04:15 PM
Posts: 561 Oakland, CA
68Bullet
Oakland, CA
Hey everyone. I'm running a 383 with a typical electronic ignition setup. It's a factory single pickup distributor and an MP orange box. I am using a factory ballast resistor. No problems for years.
Recently though, the car started having some difficulties starting up. It would crank with no results, but sometimes when I let go of the key the engine would start up. I suspected it wasn't getting power while cranking, so I had a friend hold a multimeter on the coil. I am getting about 8 volts key on, and 12 volts while cranking. However, I am still having intermittent startup issues (doesn't do it every time, but acts up more so when hot). Is it possible the orange box can be getting power but not triggering the spark? Does a warm engine bay effect the box?
"Broke is temporary, cheap lasts forever"
Re: Orange box doesn't provide spark while cranking?
[Re: 383man]
#1285347
08/14/12 06:24 PM
08/14/12 06:24 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
If you have an older orange they work fine. I bought mine in 2002 and it is still working fine on my 63. It works good enough to run 10's without missing a beat. But the box is not your problem. The ign switch bypasses the ballast while cranking and supplies the coil and orange ECU voltage while cranking. If I would suspect anything I would think the ign switch may be your problem. Did you check the voltage at the coil and ECU when it would not start or was it starting ok when you checked it ? Ron
makes alot of sense
[Re: mikemee1331]
#1285348
08/14/12 07:42 PM
08/14/12 07:42 PM
68Bullet
Oakland, CA
I also suspected the ign switch. That is why I had my friend use a multimeter to check voltage at the coil positive terminal while cranking. He read a full 12 volts at the coil while cranking, but no spark. That is why I suspect the orange box. However, it is sounding like it could also be the coil too.....
[Re: 68Bullet]
#1285349
08/15/12 10:36 AM
08/15/12 10:36 AM
Posts: 1,051 The Great White North
RAMM
Probably pick-up coil. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1285350
08/15/12 11:17 AM
08/15/12 11:17 AM
RapidRobert
My vote: pickup coil or ECU
