is it OK to reuse head gasket? HEMI #1285098
08/14/12 12:40 AM
08/14/12 12:40 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I have a HEMI that was completely rebuilt but that was a few years ago....like 4....and its been sitting since...
I have turned it by hand every now and then, but probably not as often as I should have....
Its got a solid roller cam (mild under 600 lift).
I am worried that the springs might have gone bad, so I want to take em off to test them....but for doing that I need to take off the heads...
I was wondering if I take off the heads to inspect,,,,will I be able to reuse those head gaskets???
The engine has never been fired, but the heads were torqued to spec....
I dont know if it makes any difference, but its got head studs.
Re: is it OK to reuse head gasket? HEMI [Re: domingo] #1285099
08/14/12 01:53 AM
08/14/12 01:53 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Hi!
I think you are worrying too much...I bet it would be 100% fine..
If you want to put your mind at rest, air up a few cylinders and pull a few springs and check them out. There are tools designed to remove hemi valve springs without unloading the head studs. I wouldn't take the heads off. That's just me.
Was thins motor sealed up good? Id be more concerned with a mouse making a nest in there if the motor wasnt sealed off well.
MB
Re: is it OK to reuse head gasket? HEMI [Re: HPMike] #1285100
08/14/12 11:27 AM
08/14/12 11:27 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, it was sealed up good. With duct tape on the ports....and with plugs installed. INtake also taped.
I dont have the tool to remove the springs without taking the heads out....
So, will the head gasket be unseable if I take a head off???? Like I said, the engine has never been fired.
Re: is it OK to reuse head gasket? HEMI [Re: domingo] #1285101
08/14/12 12:00 PM
08/14/12 12:00 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
What kind of head gaskets?
Has it ever been started and been warmed up?
IF you have never started it and the springs have never been heat cycled, then I would not worry about them.
Old Geezer Racing
Re: is it OK to reuse head gasket? HEMI [Re: SCATPACK 1] #1285102
08/14/12 12:22 PM
08/14/12 12:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
ENGINE HAS NEVER EVER BEEN STARTED. But its been sitting close to 4 years, I have turned it by hand every now and then.....but probably not as often as I should have....
Lifters are crowers solid rollers. http://www.summitracing.com/parts/CRO-66232-16/
Springs are PSI 1240. THEY ARE BRAND NEW, NEVER BEEN HEAT CYCLED- http://www.cvproducts.com/ProdDet.aspx?PN=PSICT1240
Dual Spring
O.D. 1.500 Seat Pressure-250@2.030"
Outside Spring I.D. 1.085 Open Pressure-610@1.250"
I.D. .795 Max Lift .780 Coil Bind 1.200
The cam is a mild steer solid roller off Dave Dudeks Old Challenger when it ran low 11s at 127 mph.
COMP solid roller
Intake- 248@.050& .604lift
>Exhaust- 254@.050 & .591lift
>Lobe sep is 114
>lobe #`s: 4875B/4876B sn#-A6105
Head gaskets are composite, not steel.
Domingo
Re: is it OK to reuse head gasket? HEMI [Re: domingo] #1285103
08/14/12 12:28 PM
08/14/12 12:28 PM
Texas
ChristianCuda Offline
Texas
Composite gaskets usually will leave some material on the head or deck surface due to compression from the heads being torqued on. If it were the steel gaskets then I wouldn't worry about it.
Re: is it OK to reuse head gasket? HEMI [Re: ChristianCuda] #1285104
08/14/12 02:10 PM
08/14/12 02:10 PM
dogdays Offline
dogdays  Offline
You worry too much. Run the doggone engine. Or if it is going to sit for longer, pull the rocker assemblies. But for a decent spring sitting for a decade shouldn't make a difference. No fatigue cycles.
R.
Re: is it OK to reuse head gasket? HEMI [Re: dogdays] #1285105
08/14/12 04:40 PM
08/14/12 04:40 PM
California
mickm Offline
mickm  Offline
California
i asked the guy at cometic and he said that if the engine hasn't been started, you are fine to reuse them. i would assume that goes for any head gasket.
i have seen threads on here where people are talking about reusing gaskets that have been run, and many people have said that works as well.
sounds like you are good to go
Re: is it OK to reuse head gasket? HEMI [Re: mickm] #1285106
08/14/12 06:48 PM
08/14/12 06:48 PM
MN
73outlaw Offline
73outlaw  Offline
MN
I would only reuse a mls or copper gasket and I would NOT reuse a composite head gasket EVER.
Re: is it OK to reuse head gasket? HEMI [Re: 73outlaw] #1285107
08/14/12 10:40 PM
08/14/12 10:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Why chance it? I'd back off the rockers until you're ready to use it.
Sheldon
Re: is it OK to reuse head gasket? HEMI [Re: HPMike] #1285108
08/14/12 11:45 PM
08/14/12 11:45 PM
tn
robnbird Offline
robnbird  Offline
tn
Hi!
If you want to put your mind at rest, air up a few cylinders and pull a few springs and check them out. There are tools designed to remove hemi valve springs without unloading the head studs. I wouldn't take the heads off. That's just me. you can change the spring w/o removing the heads.
MB
