Voltage regulator wiring #1284721
08/13/12 06:52 PM
08/13/12 06:52 PM
Kingston, OK
racerb440 Offline OP
Kingston, OK
On the pre 69 electronic voltage regulator, there is a pigtail and a post.Which is the 12v feed(ign), and which goes to the field post on the alternator. Thanks for the help.
Bob - 67 Dodge Coronet 11.35,116.95 at 5880'
Re: Voltage regulator wiring [Re: racerb440] #1284722
08/13/12 08:53 PM
08/13/12 08:53 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
here is what i got when i put in avg search for 68 dodge dart with v8
http://www.valiant.org/electrical-diagrams.html
but it looks like green is your field wire and the blue wire is your 12V switched
mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Voltage regulator wiring [Re: mopar65] #1284723
08/13/12 09:05 PM
08/13/12 09:05 PM
Kingston, OK
Kingston, OK
Thanks, but the original wires are gone, so I am making a new harness,and I don't which post is which on the regulator. Would be nice if Mopar would put some kind of labeling on the regulator.Also , thank you for your service.
Re: Voltage regulator wiring [Re: racerb440] #1284724
08/13/12 09:16 PM
08/13/12 09:16 PM
mopar65 Offline
mopar65  Offline
thanks for the kind words also the reg is not marked which is which? is there a reason you want to stay with the points stile reg? i mean for factory looks? if not i would wire the car up for a 73 electronic voltage regulator. Mopar65
Re: Voltage regulator wiring [Re: racerb440] #1284725
08/13/12 09:20 PM
08/13/12 09:20 PM
mopar65 Offline
mopar65  Offline
here is some good info for you. read the first paragraph. hope this helps. Mopar65
http://www.mymopar.com/charging.htm
Re: Voltage regulator wiring [Re: mopar65] #1284726
08/13/12 09:21 PM
08/13/12 09:21 PM
Kingston, OK
Kingston, OK
This is not the points style regulator. It's the the electronic race regulator (PN 3690732) for pre 69 cars.
Re: Voltage regulator wiring [Re: racerb440] #1284727
08/13/12 09:43 PM
08/13/12 09:43 PM
mopar65 Offline
mopar65  Offline
sorry i don't think i am going to be much help.
But reading this
This green wire is connected at the voltage regulator at the "FLD" connection (with a screw). The other connection on the voltage regulator is a blue wire with a female plug end. This is the "IGN" Ignition side.
but if i am reading this right the green wire will hook up to the stud on your race regulator and the blue wire will hook up to the pig tail coming off your race regulator. again sorry if i am no help. Mopar65
Re: Voltage regulator wiring [Re: mopar65] #1284728
08/13/12 10:10 PM
08/13/12 10:10 PM
Kingston, OK
Kingston, OK
That helps a lot. Thanks again.
