Voltage regulator wiring
#1284721
08/13/12 06:52 PM
08/13/12 06:52 PM
Posts: 62 Kingston, OK
racerb440
Kingston, OK
On the pre 69 electronic voltage regulator, there is a pigtail and a post.Which is the 12v feed(ign), and which goes to the field post on the alternator. Thanks for the help.
Bob - 67 Dodge Coronet 11.35,116.95 at 5880'
Re: Voltage regulator wiring
[Re: mopar65]
#1284723
08/13/12 09:05 PM
08/13/12 09:05 PM
racerb440
Kingston, OK
Thanks, but the original wires are gone, so I am making a new harness,and I don't which post is which on the regulator. Would be nice if Mopar would put some kind of labeling on the regulator.Also , thank you for your service.
[Re: mopar65]
#1284726
08/13/12 09:21 PM
08/13/12 09:21 PM
racerb440
Kingston, OK
This is not the points style regulator. It's the the electronic race regulator (PN 3690732) for pre 69 cars.
[Re: mopar65]
#1284728
08/13/12 10:10 PM
08/13/12 10:10 PM
racerb440
Kingston, OK
That helps a lot. Thanks again.
